Car Knocker
urban myth or true?
Seeing how gas prices are way up and our truck are not known for thier gas milage, I thought I would bring this up. Yesterday when I was fueling up super unleaded @2.19 a gal, a guy walks up and tells me that if I would put a handfull of moth balls in my tank when I fuel, I could run lower octane and save 20 cents/gal. He said that when they melt in your tank they raise the octane level. That is what he does in his truck and race car. Man, I haven't heard this since I was a kid. Is it a myth or is it true? Needless to say, I have not done it, and when he drove off, by the sound of it, he will be walking soon.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
The oddest Todd around
I don't know about raising the octane, but I do know that your car will move with moth balls in the tank. But then again, the moth balls will cause the engine to run so hot that the pistons will start to melt. put too many in and you'll actually have holes in the pistons. I've done like 2 or 3 moth balls before in my 81 buick. She ran like a raped ape like that. My friend saw what it did and put a handfull in his tank. A few days later he was looking at crate motors at the dealership to replace his ruined one.
19gal tank x $.20 savings per gallon of gas @ fill up time is $3.80. Is that worth destroying your motor?
If you ran the tank completely empty & had a formula to precisely measure out moth balls to gal/gas ratio, you possibly wouldn't damage anything. If you don't get a good ratio . . .... all it takes is once.
Mothballs have a very high nitrogen content. When they dissolve, the nitrogen dissipates into the gas. Its kinda like a backwoods nitrous.
Definately not good for the engine. Now, if you have a new engine on the way & want to send your old block out w/ a bang... put in a box of mothballs & you could have one Hell of a last ride!
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
From what I have heard, mothballs will raise the octane level, but im not sure it is that good for your fuel system.
Just sitting here contemplating contemplation. |
#6 | |
http://www.freerepublic.com/focus/f-.../posts?page=11
I think some anti-Pick-Up/SUV activist is yanking your chain and trying to get you to blow your engine up. Yes, moth balls will cause your engine to "melt down". We use to do it as kids to old motorcycles that we were getting ready to junk. They'd run like a bat out of he77 for a while.....
Martin Gibson
USAF Retired 1964(-ish) C10 |
#8 | |
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS Last edited by tom hand; 05-22-2004 at 07:22 PM. |
its all about the +6 inches
It is an old hot rodders trick, but everyone here is right, it'll blow your motor up.
72 Cheyenne
I heard that the old napathane moth ball weren't available anymore, I've looked around for them but have never seen them in any store. Do they still make them?
Car Knocker
No, I'm not gonna do it. I can tear my stuff up easily enough without dumping something in the tank. Like I said earlier, I believe that by listening to his truck when he left, he'll be walking soon. Just wanted to know if anybody else had heard of this before.
#12 | |
Binder Rep
There are two types of moth balls. One will raise the octane level. The other will blow the engine up. The one that raises the octane won't hurt anything, but you only need like one for a full tank of gas.
Raising octane would be easier on your engine if you are easy of the happy pedal... means that the fuel burns cooler etc. Lower octane burns faster and hotter. |
$2.19 for Super, try $2.70 out here in So Cal.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
#15 |
Slam, how much tax are you paying a gallon? I'll bet your state is screwing you at the pump in addidtion to everywhere else you get/spend money.
#16 | ||
72 Cheyenne Super 4x4 SWB |
