Old 01-05-2019, 07:25 PM   #1
tucsonjwt
AC Vent Door Eye Loop
I am putting back together the interior of my 83 C20 with factory ac and I can't remember what this center loop feature is for. I think the silver colored u shaped hook with the teflon speed nuts attaches to the vacuum canister bracket, but I don't know if this center loop connects to anything. Can anyone identify the purpose and connection (if any) on the circled loop on the vent door? Thanks.
tucsonjwt is offline   Reply With Quote
Old 01-06-2019, 01:33 PM   #2
Dead Parrot
Re: AC Vent Door Eye Loop
A spare one of those on my shelf has a spring hanging off the circled thing and the vacuum pot connected to the silver U.
Dead Parrot is offline   Reply With Quote
Old 01-06-2019, 11:13 PM   #3
tucsonjwt
Can you post a pic of that spring? Thanks.
Old 01-07-2019, 06:18 PM   #4
tucsonjwt
I found a 73 C10 with factory a/c at the Pull-A-Part. The spring connects to a small hole in the bottom of the vacuum canister bracket. I found my missing spring after I bought the "plenum valve" assembly with spring attached. Thanks for the help.
Old 01-08-2019, 04:45 PM   #5
Dead Parrot
Glad you found a useful part. This is a pic I took of the one on my 75 before seeing you had solved your question. In case someone else has a similar question.
Old 01-10-2019, 09:28 PM   #6
tucsonjwt
One difference is the kick panel cover on my Silverado is much larger than the half size panel on the basic trucks. I think the one I got off the junkyard 73 also has a somewhat smaller plenum valve, but I have not taken the two apart to compare them.
