67-70 center link
It appers I have a 71+ center link that I didn't realize when I tore my front suspension apart and replaced it all. I have 67-70 ball joints and spindles and am looking for a 67-70 center link, but it doesn't seem like hardly anyone makes them. Does anyone know where I can source one from?
![]() Join Date: Sep 2007
Re: 67-70 center link
those always get replaced when guys do the disc brake / power steering conversion. ( a must ) if you have been swapped to disc brakes and/or power steering you really should just get 71 inner and outer tie rods. or cpp sells the conversion rods.
if your manual steering and drums in the front just look for one on the for sale ads on here
1967custom |
#3 | |
Never Ending Projects
Yeah, no one makes the center link because it is a non wear item. You will have to find a used one. I had to swap mine out because someone used it to pull the truck and put a curved bend into it. I found a guy parting out trucks on Craigslist and got one that way.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#5 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Run some conversion tie rod sleeves with 67-70 outers. Then you can use 71-72 tie rods to connect to your center link. Here’s the catch: 67-70 outers are LH thread. So you will need to use 71-72 outers (rh thread) in the inner location.
#6 | |
Is there a difference between 71-72 outers vs inners ball joint size? Or are 73+ tie rods different than 71-72? Looks like they have different part numbers on Moog's website.. Either way I need an outer to run in the inner location. |
71-72 tie rods are the same, no matter inner or outer, just different thread direction.
Tie rods are: 63-70 71-72 73-87 Same as balljoints.
OK so i've tried 67-70, 71-72, and 73-87 tie rods and none of them work with the center link I have. The taper on all of them is too small for the center link so they fit sloppy. The taper on the center link is the same size for all 4 of the holes. The idler/pitman arm taper fits in every hole on the center link if that explains anything.. I'm open to any suggestions, at this point I have enough tie rods to build a front end twice over...
I would highly suggest you read Lolife99 information posted here in Suspention go to the thread/thread stater catorgory and click on Lolife99 DISC TO DRUM Conversion ,he gives you very detailed information on what you are trying to figure out . all your answers are there
#10 | |
I know this shouldn't be this complicated but I appreciate the help. Lesson learned, don't toss your old parts until you verify the new parts are correct. |
I think the taper increased in size as they got newer. GM kept beefing them up. I wonder if the center link is from a C20 or C30. They might have used bigger tie rod ends.
Turns out inner tierods from my 77 fit the taper on every hole of the centerlink he has. So he could use 75+ inner tierods and solve that issue but he still has the 67-70 spindles and they use a slightly smaller taper and smaller threaded end to go to the adjuster sleeve so either someone makes a tierod that has the larger threaded shank for the adjuster or we will have to drill the taper larger to use a 75+ outer tierod also
