01-05-2019, 12:11 AM | #51 |
Re: Just got an NV4500, can't find the oil
Where did you find the oil? Did it come with the kit from AA?
01-05-2019, 12:21 AM | #52 |
I got it from Summit, 21.99 qt
My 57 GMC build |
01-07-2019, 10:06 PM | #53 | |
By the time I smelled the oil leak - I lost enough trans fluid to burn both main brgs & burn 3rd gear... I bought a 2 ft piece of B-7 boiler allthread for the studs and grade 8 lock washers and nuts and haven't had any problems since. FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's Last edited by Feel the 'Pane; 01-07-2019 at 10:16 PM. |
01-07-2019, 10:40 PM | #54 | |
My 57 GMC build |
01-08-2019, 12:01 AM | #55 |
Yep, I made the same tool & used loctite as well but the cap screws still came loose. I don't abuse my truck but still had the problem hence my post.
I guess the person packing up my kit wasn't paying attention as the kit came with extra metric & not enough SAE fasteners. FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
01-08-2019, 12:23 AM | #56 |
I'll keep an eye on them and see if they stay tight. There was 8 metric bolts for the tall housing, 8 SAE for the figure 8 to round transfer case adapter, and 6 SAE for mounting the adapter to the tail housing. I opened everything when it came, and the parts list matched everything I received, but the instructions jumped around in the steps and left out several items, but I already knew how everything was supposed to get installed. I mainly just made sure that I had all the parts that it was supposed to have in the kit.
My 57 GMC build |
01-08-2019, 09:08 PM | #57 |
Back in 2014 when I got my kit, it came with 8 bolts for the T-case plate and the rest were metric & 2 did. lengths. I didn't get upset until I found out the seal was the wrong size. Throw in the weak t-case shifter bracket....
FtP
