![]() Join Date: Jul 2001
Steel Floor Sections
Have a three large pieces of a steel bed floor from a parted '71 1/2 ton. Prefer local pickup or possible delivery but will ship at buyer's expense. Have one section that is 18'' x 50'' , one section that is 20'' by 50'' and a larger section that is 31'' x 72''. Two smaller sections are $40 picked up and the large section is $50 picked up. Possible delivery near Wichita, Ks. is also an option. Will ship thru UPS with money order payment, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: Steel Floor Sections
Under side of largest piece with support ribs. Corner of one rib is rusted.
Any interest for possible pickup or delivery within local area? Hate to scrap good floor patch material.
Good floor patch material, still available.
Good floor patch panels. Prefer local pickup or possible delivery for gas $$. Will ship the two smaller panels via UPS on buyer's $$
Good original GM floor patch panels.
Can I have a estimate to ship to 58130.
Which floor sections are you interested in? The smaller size, mid size or the larger one with the ribs?
UPS only way open to me for shipping locally. Tried a Fastenal quote once and had to ship from a Fastenal location nearly 40 miles away from me. Was not feasible to do.
#9 | |
Just guessing by your Fargo location that's Fargo, North Dakota? Need a zip code to figure shipping. UPS is usually a bit cheaper if delivered to a commercial business address over a residential address if you have such available to use. Can get a quote after a zip code, thanks for the interest.
#11 | |
Saturday morning bump
PM sent with shipping quote and info. Let me know if interested.
Original GM sheet metal floor repair panels still available.
#15 |
On the larger piece where the corrugations taper at the top of the picture, would you be willing to cut that end off say right along the lower side of the cross sill to give me a 6 inch wide by 18 inch section? Thanks
#16 |
Bob, had hoped to sell the floor sections in the larger pieces but while have had interest, shipping large, heavy sections like these is a deal killer. I therefore have considered just cutting up as needed for various patch panels. I did look this morning at that section you are interested in. It is solid to include the cross member portion underneath.
The bed floor carriage bolt hole is solid and square, no rust or rounded corners. A 6'' wide section clears the cross member underneath by approx. 1 1/4'' of clear metal. From the outer edge inward the bed floor carriage bolt is at approx. 23'' so to the edge of a rib is about 19''. Can cut that portion if wanted and then proceed to offer any other patch panels in another thread. $25 plus shipping. Shipping will be a bit $$, not sure exactly how much unless I have it cut. I'm sure you have read of the shipping costs now days. Let me know if that works for you. Really rather not cut a floor section until there is a definite want for that piece. I don't have Paypal, money order payment only.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 01-09-2019 at 01:53 PM. Reason: Can't type, LOL. |
#17 |
That would probably work. I don't need the cross member underneath, just the floor panel itself, so you can cut as much away of that also to lighten it up for shipping. Let me know if that is ok and you can PM me your address for where to send the MO.
Thanks,Bob |
#18 |
Bob, sending a PM to make sure we are on the same page for the cuts and dimensions.
