01-05-2019, 07:25 PM | #1 |
AC Vent Door Eye Loop
I am putting back together the interior of my 83 C20 with factory ac and I can't remember what this center loop feature is for. I think the silver colored u shaped hook with the teflon speed nuts attaches to the vacuum canister bracket, but I don't know if this center loop connects to anything. Can anyone identify the purpose and connection (if any) on the circled loop on the vent door? Thanks.
01-06-2019, 01:33 PM | #2 |
Re: AC Vent Door Eye Loop
A spare one of those on my shelf has a spring hanging off the circled thing and the vacuum pot connected to the silver U.
01-06-2019, 11:13 PM | #3 |
Can you post a pic of that spring? Thanks.
01-07-2019, 06:18 PM | #4 |
I found a 73 C10 with factory a/c at the Pull-A-Part. The spring connects to a small hole in the bottom of the vacuum canister bracket. I found my missing spring after I bought the "plenum valve" assembly with spring attached. Thanks for the help.
01-08-2019, 04:45 PM | #5 |
Glad you found a useful part. This is a pic I took of the one on my 75 before seeing you had solved your question. In case someone else has a similar question.
01-10-2019, 09:28 PM | #6 |
One difference is the kick panel cover on my Silverado is much larger than the half size panel on the basic trucks. I think the one I got off the junkyard 73 also has a somewhat smaller plenum valve, but I have not taken the two apart to compare them.
