Need help with speedometer cable end piece I知 lost as heck on this one.
1972 Chevy C10 longbed fleetside with 402 and 4 on the floor.
I need some help, finally finished upgrading G and updating a ton on this truck and got it on the road only for the speedometer to start bouncing around. Pulled the speedometer wire and it痴 not broken replaced it anyways with new wire now nothing. There was a tiny plastic tip on the tranny end of the wire which my local auto part store said I didn稚 need and I dropped it somewhere between there and my house. Turns out around do need a new one to this piece. It was worn out. M Mi removed the speedometer gear at the tranny only to find out that a standard square end wire will not work. Autozone has no clue my local autopart store does not either. The hole the wire goes into is round with a small slot that the wire end piece sits in to make the wire spin. See pics. I have no idea what transmission is in this thing since it痴 not the original which was automatic. Any help would be appreciated. Also how do I find out what tranny it is. The picture where I知 holding s steel pin goes into the side of the transmission I filed flat the straight end of a cotter pin and slid it in the gear along with the speedometer wire just as a temp fix and it worked but not sure how long it will last.
Cesar Diaz 1972 C10 Big Block 402 Cheyenne |
Re: Need help with speedometer cable end piece I知 lost as heck on this one.
It’s called a ratio adaptor.
New ones or small parts available here. There should be a ratio stamped on it. https://transmissioncenter.net/ |
I believe the piece your missing must be a speedometer adapter key. NAPA carries them or you may have a local shop that does speedometer calibration that should stock them
https://www.napaonline.com/en/p/BK_6151833
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thank you for the response if the speedometer key is the part that goes into the tranny I actually have that. What I. Need is the small plastic piece that goes on the end of the wire that goes into the speedometer gear. Unless I知 misunderstanding but I will check Napa as well I知 not a mechanic, Just a do it yourselfer, working on my kids first truck.
Thanks geezer was not sure if the name, the ratio adapter I have works fine I just need the small tiny plastic tip that goes on the end of the speedo wire that inserts into the ratio adapter.
#6 | |
HO455 that is exactly the piece I need this k you.
Your welcome and good luck.
| Bookmarks |
