Old 12-29-2018, 07:27 PM   #1
cgster
Emergency Brake question
Looking at a 67 truck that at some point had the ebrake removed. How hard is it to install an emergency brake?
cgster is offline   Reply With Quote
Old 12-29-2018, 07:38 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Emergency Brake question
it's not hard ,It all depends on whats missing . all the parts are available .
Old 12-29-2018, 07:41 PM   #3
cgster
Ok, im assuming most of the parts are missing. I haven't had time to get a detailed look.
Old 12-29-2018, 08:39 PM   #4
jayoldschool
Moderator
I had to replace the entire system on my 65. Someone had cut the e brake cables at the drums, removed the components inside the drums, taken off all the cables, and even the handle inside. Rebuilt it all with a mix of used and repop. Didn't cost much. Works perfect.
jayoldschool is offline   Reply With Quote
Old 12-29-2018, 08:56 PM   #5
jocko
jocko's Avatar
Keep in mind you'll need pre-68 parts (67, 66, 65, etc..) - the floor pedal came in at 68, below column pull lever 67 and earlier. I assume you know all this, mentioning JUST in case, since you said you're looking at it (i.e. if not familiar with 67s, you wouldn't be the first to look for a floor pedal and think the parking brake is missing) Like I said, assume not news to you, but JUST in case
Old 12-29-2018, 09:54 PM   #6
MySons68C20
MySons68C20's Avatar
My 68 has the arm powered e brake handle. I can pic up if you would like.
MySons68C20 is offline   Reply With Quote
Old 12-30-2018, 12:02 AM   #7
cgster
I thought floor pedals began in 69 and the 67-68 both and the hand lever below column?
Old 12-30-2018, 02:04 AM   #8
jocko
jocko's Avatar
I believe you all are absolutely correct - I could've sworn it was early 68 when the changeover occurred, but as I look back all the old 68 interior pics I have - they all have the pull same handle as the 67 and earlier. Thanks for correcting!
Old 01-14-2019, 11:12 PM   #9
Kevin7723
Kevin7723's Avatar
Ive got all the parts to rebuild mine from lmc truck and looking through the forums and other guides it doesn’t seem to hard to get everything installed.
Kevin7723 is offline   Reply With Quote
