Old 01-14-2019, 05:40 PM   #1
Whamp48
Junior Member
Reduction gear starter
Hey guys, anyone know for absolutely sure where to get a gear reduction starter that will fit a BB 402, automatic 400, 168 tooth flywheel? I just bought one from NAPA that the paperwork said would fit,it didn't. So, now I'm stuck with a $270 starter that is useless to me. If someone knows where to get the right one, and maybe the part number, I would appreciate the information.
Whamp48 is offline   Reply With Quote
Old 01-14-2019, 06:22 PM   #2
hjewell2
hjewell2's Avatar
Re: Reduction gear starter
Powermaster 9526 - Powermaster XS Torque Starters
Powermaster 9612 - Powermaster Mastertorque Starters
hjewell2 is offline   Reply With Quote
Old 01-14-2019, 06:59 PM   #3
Whamp48
Junior Member
Thank you sir. I think I saw those on Summit. Have a good day!
Old 01-15-2019, 12:25 AM   #4
AJC
Another option is the gear reduction from a gm 8.1 big block. Get the starter bolts from a dealer. You need 1 of each bolt. Total cost is less then $7 bucks and fit the best.
Part Numbers
  • Starter - GM (10465578)
  • Starter Mount Bolt - GM (12561848)
  • Starter Mount Bolt - GM (11610787)
AJC
AJC is offline   Reply With Quote
Old 01-15-2019, 06:46 AM   #5
Whamp48
Junior Member
Thanks, AJC
Old 01-15-2019, 10:06 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2
Old 01-15-2019, 09:05 PM   #7
Whamp48
Junior Member
I'll check it out. Thanks.
Old 01-15-2019, 09:29 PM   #8
Whamp48
Junior Member
I took it back. I got a lady salesperson who knew very little, and I now own an expensive wheel chock. To the guy with all the tooth counts and mounting locations, thanks, but that doesn't make this starter fit my motor.
Old 01-15-2019, 11:09 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Have them on 3 of my 4 vehicles two 454s and one 400 sb and it starts with 36° initial timing.
Old 01-15-2019, 11:59 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks like you now have it under control, but I bought mine at a local speed shop and luckily got it right the first time. A good counter person makes all the difference in the world. It doesn't seem to engage a lot of the flex plate (which is the original, at 217k miles). The flex plate will be replaced soon.
~Steven
Simi Valley, CA
Old 01-16-2019, 12:34 AM   #11
Whamp48
Junior Member
Thanks guys, I appreciate the help. I should have got on here first, but the guy who sold me the starter was sure it was correct, the paperwork says it will fit a big block, a small block and even a 4.3 V6. Maybe if they all had the small flywheel. Oh well, expensive lesson learned. I'm gonna see if my credit card company can help me out with returning the starter, but if not, lesson learned. You fellows have a great day.....Warren
Old 08-15-2019, 12:20 PM   #12
Astro-Balls
Astro-Balls's Avatar
Part Numbers
Will this starter also fit the '68 396 4sp??
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-21-2019, 08:07 PM   #13
AJC
It needs to be a 168 tooth flywheel. But I have read that the manuals trans require a cast-iron nose starter. something about the nose fitment into the bell housing being different between the aluminium and cast iron nose size. I don't have any manual trans so I can"t say for sure. The later starter may work. All I can confirm is it works on 168T automatics. If you do try it let me know.
AJC
Old 08-22-2019, 07:32 AM   #14
Mike C
Mike C's Avatar
67-72 with manual trans used a bellhousing mount starter and not block mounted. It is possible to use a later style gear reduction starter. Chances are the GM style gear reduction unit would work, but on my Jimmy I used a non-supported nose Denso style starter which works great.
Whatever parts store sold you the wrong part and wouldn’t take it back sux.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
