#26 | |
Re: 67 SWB First Build
Thanks, this is my first time doing this major of a project as well... |
#27 |
Finished stripping the passenger door outer skin. Will run the DA over it before I epoxy prime. Started filling the trim holes in the door as well as the badge holes. There were also some small dents that the previous owner just used filler over. I used the stud gun to start working them out. Still a little more to do, as well as old mirror holes to fill.
Last night I used some body filler on the dash. Still a little more to go over. I'm trying to decide on which suspension kit to go with. Really looking hard between the ridetech street grip kit and the QA1 coilovers kit. If anyone has any opinion on either, it'd be great to hear. I'm gearing up to start accumulating parts for the chassis. Al |
#28 |
Spent the evening in the shop tonight while the lady was out of town. Had a good night out there with the body work on the roof and passenger door. Need to touch up that body line on the back of the cab better. I removed the dents in the door from the PO. Also nearly have all the paint stripped off the door. All those tight grooves are tough to get to.
Goal this weekend is to get the door, driver fender and tailgate in primer. Cheers Al |
#29 |
![]() Join Date: Jun 2002
Nice progress. Where did you get the shrinking tip for the stud gun? I have a cheap HF gun and have oil can dent on my bedside.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#30 |
Nothing like a cup of Jack to get the job done, looking good!
#31 | |
I got the shrink tip from my dad who owns an auto parts and paint supply store back home. He has really helped me get my tool arsenal put together. I'm sure your local auto parts store has them, or last resort you can get them on Amazon. |
#32 |
#33 |
Didn't quite get everything done this weekend like I wanted to, but did make some progress. Finished stripping the passenger door and the driver fender. This afternoon I was able to get some 2k epoxy primer on the fender and door. Ran out of time to get the tailgate. Will try to get it next weekend.
Cheers Al |
#34 |
![]() Join Date: Mar 2011
Nice progress I’ll jump in for a ride if you don’t mind
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#35 |
Man it seems like I've been putting in the time but not much to show for it. I've been continuing with the paint stripping on the tailgate. The tailgate was pretty abused back in the day and there are quite a few little dings that have some surface rust in them. Trying to get in all of those little spots has been time consuming. Also I have been pulling the larger dings out with my stud gun. I'm half tempted to cut it open if it continues to be a pain.
While the air compressor is reloading for the DA on the tailgate I've been working on the grill trim. There were some small dents and it was sightly bent in a few locations. Used a hammer and some punches to work out those defects. |
#36 |
Last night I was continuing on stripping the paint from the tailgate and pulling some of the small dents when I made a discovery. It looks like the tailgate has a pretty large bow in it...
At this point I'm not sure it's worth my time trying to fix that, as well as clean up all of the dents. I'm leaning towards buying a new tailgate. Anyone have any thoughts or advice? I didn't take a very good photo. I would say it's close to 3/8" - 1/2" bowed at the middle of the bottom of the tailgate. While pondering that decision I decided to switch gears. I temporarily installed the driver front fender to see the fit with the door. That revealed some additional bodywork I needed to do to the door. I'm pretty sure this door used to have the large camper style mirror and at someone it was side swiped because there was some damage where it attached to the door skin. So I'll start working those dents out this weekend. Al |
#37 |
![]() Join Date: Jan 2013
I got mine thru Nsane Hotrodz 856-761-0460, Great service and easy to deal with. I got the one that is plain.
#38 | |
![]() Quote:
Great progress, very nice work. Question. How did you get all the seam sealer out of your roof seam? I am a little behind your progress and am thinking of doing that same thing but a wire wheel didn't remove all the sealer when I did my floor pans sooo...... Keep up the good progress, it will start coming together before you know it.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#39 |
#40 | |
It wasn't too bad of a chore. The seam sealer was pretty dried up and semi brittle. I used an old small and beat up flathead screw driver and hammer to chisel it out. Just made sure that I wasn't going too hard with the hammer to deform the edges. It took about an hour to get it all clean. I flipped through your build and it's starting to take shape. Nice work! Good luck removing the sealer. I'm sure you won't have much trouble. |
#41 |
Maybe search ebay or the for sale section on here.. shipping might cost a bit.. but it would be original
#42 |
Yeah that is probably the route I'll go. It would have been a cool patina tailgate, but unfortunately that's not the route I'm going. Fingers crossed I can find something local.
#43 |
#44 |
My dad came up for the day to give me a hand with some of the bodywork. We started putting some glaze on the fender and cab. Things are starting to look and feel pretty dang straight!
Also used my little sandblaster gun to clean up backside of the grill trim. Worked pretty good. Will continue on the bodywork for the cab and body panels for the time being. Also ordered a new Boyd fuel tank for the rear of the truck. Will slowly start accumulating parts for the chassis. I'm feeling pretty good about having the cab and body panels in primer by middle of spring ![]() |
#45 |
Looking good man. I hope to have mine pretty ready for paint by then too... I'm off for a few weeks so that helps but your looking like your going to hit your timeframe no problem.
Are you building a DD or a trailer queen?
#46 | |
Nice job on all your metal work btw. Looks like you're making some awesome progress. |
#47 |
I started the bodywork on the passenger fender last night. Finished sanding the body filler and now getting going on the glaze. Probably the toughest part about it is sanding in all the grooves by the headlight.
Question - what do most people do with the interior of the fender? My plan was to remove the little bit of surface rust and then coat It. I'm not entirely sure what type of product to use. Thanks Al |
#48 |
Could just remove/sand the rust and then paint it...
#49 |
when doing our builds, we prep as if for paint, Direct To Metal (DTM) primer, then color match exterior paint with Raptor Liner.
The picture shows the underside of the hood and the front fenders, but we do the bottom of the cab, underside of bed, underside front fenders, and wheel tubs in the back the same way.
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
#50 |
Spent a few hours in the shop this weekend. Used that time to finish sanding the passenger fender. Something about sanding makes progress seem so slow... Going to start on the body filler for the passenger door this week. Once I get the doors all sanded I'll get ready to spray some high build. Giddy up!
Al |
