01-15-2019, 03:50 PM | #1 |
air ride manifold mounted inside?
I have airlift 3p for my truck. It seems like a lot of people mount them under the bed where you cant access them unless your bed floor lifts up. I thought about mounting it inside with the ports facing down and shoot the airlines straight down thru the floor. The only downside I can see is id have 6 holes in the floor now. But the manifold would be protected from the elements.
01-18-2019, 08:39 PM | #2 |
Re: air ride manifold mounted inside?
I had the manifold behind the seat in my 65 worked just fine. I also had the compressor back there.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-19-2019, 10:08 AM | #3 |
I have the tank,comp and valves all in my blazer behind the seat, might move the tank under if I can find room but all I have to do is unhook a couple lines and the whole assembly comes out in one piece
01-19-2019, 10:58 AM | #4 |
Do you guys have all the lines going thru individual grommets, one big grommet or bulkhead fittings?
