Old 01-09-2019, 07:41 PM   #1
partssman
partssman's Avatar
66 c50
I have a 66 C50 and was wondering if making it 4x4 is doable without spending a fortune. Can you guys point me in the right direction?
partssman is offline   Reply With Quote
Old 01-16-2019, 12:11 AM   #2
Re: 66 c50
I'd say with the front drive axles for large trucks being so uncommon you'd be lucky to find one cheap, as well as the rest of the conversion parts.
Old 01-16-2019, 01:20 AM   #3
kwmech
Re: 66 c50
Are you looking to put in a Dana 60 or a med duty axle?
Old 01-20-2019, 04:42 PM   #4
partssman
partssman's Avatar
Re: 66 c50
Medium would probably work fine. Getting around in the snow and on the farm would be all it'd be used for. Nothing severe
Old 01-20-2019, 09:41 PM   #5
franken
Re: 66 c50
The OP needs to look at the trans to see what it is (SM420?, and the rear diff to see what it is, ratio, and lug pattern. I'd also research what TC was used in that vehicle. If it's the same as used in a light duty, I'd be looking for an 465/205 combo from a later truck.
Old 01-21-2019, 03:18 PM   #6
sweetk30
sweetk30's Avatar
Re: 66 c50
if i ever do a med duty and 4x4 my plan is to start big .
late model dodge dana 80 rear axle x2 . put 1 in the rear and make my own front axle with aftermarket outer parts and stuff . it would be king pin like a 60 but run basicly ford 550 outer stuff for the beefy like brakes / axle shaft & u-joints that are bigger than dana 60 king pin stuff .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-26-2019, 07:59 PM   #7
kwmech
Re: 66 c50
There was (for a few years) a dana 70 front that they were putting under the Kodiak med duty truck. I think they only had 1 gear choice though---5.13s I think
Old 01-26-2019, 09:39 PM   #8
sweetk30
sweetk30's Avatar
Re: 66 c50
and hard to get parts for .
