Old 01-22-2019, 02:36 PM   #1
Magicnbomber90
Tail light problem
I have a question for the masses ? Installed my new tail lights thinking that it’d fix the problem of my passenger side brake light not coming on when I press the pedal but it didn’t. Everything else works on the truck like the signals and the running lights and such except the passenger brake light . Thank you in advanced
Magicnbomber90 is offline   Reply With Quote
Old 01-22-2019, 06:46 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Tail light problem
What do your grounds look like?
Old 01-22-2019, 07:54 PM   #3
1998c1500
1998c1500's Avatar
That is odd because I think there are only 2 wires going to each taillight. the turn signal and brake light run on the same wire.(yellow or dark green)Tail lights would be brown. If you turn the lights on and put on the emergency flashers, are the left and right lights all the same brightness?
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 01-22-2019, 07:58 PM   #4
shp4man
shp4man's Avatar
The brake light power circuit goes through the turn signal switch so that they keep flashing when when you put on the brakes. Needs to be pintested down on the connector where it easier to get to.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 01-22-2019, 11:13 PM   #5
Magicnbomber90
Another thing too is I have to press up on the switch firmly when I want my right turn signal to work , the grounds looks good I cleaned them up with some steel wool I was wondering if I can splice some extra wire onto the ground on on the light and run it to the housing a bit better.
Old 01-22-2019, 11:14 PM   #6
Magicnbomber90
I cleaned the outside of the socket and the housing part that it slides into
Old 01-22-2019, 11:15 PM   #7
Magicnbomber90
Yes there is two wires I heard that the actual light grounds to the bucket. But the turn signal works fine both directions and the driver brake light works
Old 01-22-2019, 11:16 PM   #8
Magicnbomber90
I’ll probably have to shoot the wire at the bottom of the connector like you said I believe it’s the dark green wire that goes to the passenger side ?
Old 01-23-2019, 12:32 AM   #9
studeclunker
studeclunker's Avatar
It could very well be that you have a problem in the turn signal. If you have to push hard to get the right signal to work, that indicates an issue there. It could be that the interrupt circuit is causing problems with the right brake light.
If the right signal works, it isn't the wiring in the rear. The problem is either in your signal switch or the wiring harness under the dash.
studeclunker is offline   Reply With Quote
Old 01-23-2019, 01:10 AM   #10
Magicnbomber90
Ok . I’ll disconnect the wiring harness and shoot around I believe it’s still the green wire out of the bunch correct ?
Old 01-23-2019, 01:13 AM   #11
Captainfab
60-66 Nut
I'm going to go with a problem in the turn signal switch.
Old 01-23-2019, 01:28 AM   #12
Magicnbomber90
I feel like replacing it since it doesn’t stay on unless I’m holding it
Old 01-23-2019, 03:27 AM   #13
kdad
clean all contact points (screws that attach housings and so forth) clean all grounds with sandpaper. That will eliminate any ground issues going forward. Your problem is most certainly in the turn signal switch. replace it and clean clean clean everything.
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 01-23-2019, 01:10 PM   #14
straight6chevyguy
straight6chevyguy's Avatar
More than likely it's the turn signal switch.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
