Old 01-20-2019, 08:40 PM   #1
mongocanfly
mongocanfly's Avatar
10 bolt gears
I'm changing gear ratios in my 3/4 ton burb solid axles...the rear is the 9.5in 14 bolt..the frontt is the Corp 10 bolt...when I called summit the "tech" told me I needed reverse rotation gears for the 10 bolt...I thought all 10 bolts wether front or rear used the same gears...Although i've never swapped a 10 bolt front...so somebody set me straight..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-20-2019, 10:50 PM   #2
kwmech
Re: 10 bolt gears
The "tech" needs a new occupation. No such thing as a reverse 10 bolt--ever. Just call again and talk to another person and order some gears
Old 01-20-2019, 11:23 PM   #3
mongocanfly
Re: 10 bolt gears
Kinda what I thought...thanks kw...Google didnt have any either
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-21-2019, 03:07 PM   #4
GSP7
GSP7's Avatar
Cool Re: 10 bolt gears
Should have got his name so we could all call Summit and ask him about his "reverse rotation gears"
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 01-21-2019, 09:59 PM   #5
Mike C
Mike C's Avatar
Re: 10 bolt gears
Wow. He must have skipped the training class that day...
Low-pinion front axles the gear sets just drive backwards. Meaning the front drives on the coast side going forward and the drive side when going backwards. LOL
We swapped a 79 TransAm Eaton LSD into the front of my kids 72 Jimmy that has 84 3/4 ton Sub 10 bolt front and 9.5" 14 bolt rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-21-2019, 10:46 PM   #6
mongocanfly
Re: 10 bolt gears
Yeah ..he kinda threw me for a loop with his responce... had me 2nd guessing myself...I'd never heard of reverse rotation in gm.....here's his response by email.....I also just noticed he said it was 8.25 also...
If you ever talk to AC dont weigh to heavily on what he says.....
Subject
Im changing the gear ratio in my GM axles...they are from a 1991 suburban 3/4t...
Response By Email (AC) (01/16/2019 04:08 PM)
Greg,
The front would be an 8.25 or a 9.25" IFS. Either should be a reverse rotation gear set. The rear could be a 10.5" rear gear or a 9.5". Both would have a 10 bolt cover.
The following would help ID the units.
http://www.diffwizard.com/DiffWizard.aspx
We appreciate your business
AC
Summit Racing Equipment
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2019, 07:44 PM   #7
b454rat
Re: 10 bolt gears
Hes thinking IFS trucks....still, dumbass should know....
Old 01-22-2019, 10:11 PM   #8
mongocanfly
Re: 10 bolt gears
I specifically told him solid front axle....so I know he knew that much...
Mongo...aka Greg
RIP Dad
RIP Jesse
