Old 01-22-2019, 03:30 PM   #1
Mr_Rich
Mr_Rich's Avatar
307 engine
This was the original engine in my first truck. It ran a lot of miles before I swapped a 350 crate engine into my '73 square body and so on. I rebuilt the 307 for a car project and the car is gone and I still have the engine on my garage floor. It was always reliable to start instantly and I really only had problems until I got stuck in heavy traffic and the engine started running hot and blew off a radiator hose. After that is started using a quart of oil every 500 miles or so. Now this engine was bored .030 over and it's a 3970020 block. Since it was a truck engine it has the 1.94/ 1.50 valve size heads. Is there a desire for this engine anywhere? I hate to scrap it since I put a lot of good parts in it when I rebuilt it.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 01-22-2019, 09:51 PM   #2
Wikid61
Wikid61's Avatar
Re: 307 engine
The biggest weak spot of these engines was the camshaft. Putting a 300 horse 327 cam or a .425-440 lift aftermarket woke them up. Someone should step up to your motor & save it. I would if you were near by, in a s10 it would fly for ChEAP>
Wikid61 is offline   Reply With Quote
Old 01-22-2019, 10:40 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Re: 307 engine
What heads did you put on it. All 307's i have seen have had 1.72 heads...
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-22-2019, 11:10 PM   #4
Wikid61
Wikid61's Avatar
Re: 307 engine
You can put a set of cheap as cheap 305 heads like I did. +.60 = 317. Really the latest Vortech will bump power even more. Like 30-40 horse. And a bit of torque. But that stock 307 cam is the power killer of all. Old timers told me of guys buying them from running cars for $100 all day (owners were going 350, like always eh?) drop in a dirt cheap factory 327 cam (1973 prices) timing chain. Add headers & a dual plane. Done.
Old 01-23-2019, 03:33 AM   #5
Mr_Rich
Mr_Rich's Avatar
Re: 307 engine
I think you're talking car 307's and this engine came out of my '73 pickup. It had the larger valve heads. My '89 GMT400 originally came with a 305 and that engine had HO heads with 1.84 intake valves.
1989 K1500 Chev. EC
Old 01-23-2019, 03:37 AM   #6
Mr_Rich
Mr_Rich's Avatar
Re: 307 engine
I built this engine with a double roller timing chain and roller rocker arms with an Edelbrock manifold. It already has some pretty good parts to start with. Before I installed the pistons/ rods I remember the crank spun in the bearings almost like a top. It spun really smooth and ran good until it overheated like I previously mentioned.
1989 K1500 Chev. EC
Old 01-23-2019, 03:39 AM   #7
Mr_Rich
Mr_Rich's Avatar
Re: 307 engine
I hope so. Thanks!
1989 K1500 Chev. EC
Old 01-23-2019, 03:45 AM   #8
Mr_Rich
Mr_Rich's Avatar
Re: 307 engine
When I swapped out to a 350 crate engine I installed Hooker headers and a Holley four barrel carb. It wasn't until I swapped out the cam in *that* engine that I realized what a change a cam can do. My Hooker headers changed a deeper shade of blue during the cam break-in procedure. I still remember that and it was thirty-five years ago in my geezer memory bank.
1989 K1500 Chev. EC
Old 01-23-2019, 09:23 AM   #9
Warrens69GMC
Re: 307 engine
The 307 that is original to our 1969 GMC had 185 heads, which are 1.72I and 1.5E
I haven't seen a big valve 307 myself.
The 307 used one of three cylinder heads -- casting numbers 3927185, 3986338 and 3998991. Casting numbers 3927185 an 3986338 are early low-rpm torque makers with 70-cc combustion chambers, 1.72-inch intake and 1.5-inch exhaust valves. Chevrolet used the 3998991 from 1970 to 1976, and it was identical to the other heads except for its larger 74.56-cc combustion chamber.
https://itstillruns.com/1968-chevy-3...s-7366711.html
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-24-2019, 08:10 PM   #10
MikeB
MikeB's Avatar
Re: 307 engine
A 307 is essentially a stroked 283, which was a cool thing to have back in the day. However, the factory 307 gets no respect because there was never even a mild performance version.
The 69 C10 I bought in the 1980s came with a sluggish 307. But a new 194/204 cam, a small 4bbl Holley 450cfm Economizer, and dual exhaust (only 2") with low restriction mufflers really woke it up. It must have made at least 25% more power, and felt less stressed-out on the highway. And gas mileage went from 10-12 to 13-14. Win, win! A pair of 327 heads, even from a 250 hp or 275 hp engine, would have probably added another 10-20% more power.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-24-2019, 08:24 PM   #11
Wikid61
Wikid61's Avatar
Re: 307 engine
Correct.^^ a 283 + 327 (large journal) crank= 307. The 327 w/a 283 crankshaft (small journal) created the high revving 302 for the autocross of the late '60's. Stay at or under the 1.94 I valve for that small bore. What other SBC got or gets a bad reputation? The 400.
Old 01-24-2019, 08:42 PM   #12
MikeB
MikeB's Avatar
Re: 307 engine
Yes, I built a .030" over 327 for a 55 Chevy car using a 350 block and a 307 crank. Got the rotating assembly balanced, and the crank journal needed some weight added due the the heavier 327 pistons.
I think the only year that the 302 used a small journal crank was 1967. (327 block with 283 crank.) I know for sure the 69 model used a large journal crank in what was essentially a 350 block. That was a very stout bottom end due in part to the high overlap between rod and main journals.
Mike
Old 01-25-2019, 03:48 PM   #13
68post
Re: 307 engine
A 307 is a better engine than a 305 (I'd consider it an upgrade), your's should sell easily.
MikeB, 302s went from 2 bolt main to 4 bolt also, those were very stout.
The one's building 305's can't use quite as big of an intake valve as the 307, as was mentioned.
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 01-26-2019, 02:51 PM   #14
Mr_Rich
Mr_Rich's Avatar
Re: 307 engine
I agree. In some forums that discussion could get quite heated as I've seen. The original 305 in my GMT400 developed a cracked block in the lifter valley at 30K miles and I was done with 305's after that.
I've tried to sell this engine on CG and Marketplace but no takers yet. It has some good parts in it. I think I will post it here as well since I'm going to have to move soon.
1989 K1500 Chev. EC
Old 01-26-2019, 03:42 PM   #15
Wikid61
Wikid61's Avatar
Re: 307 engine
This^^. The 305 head also has the hardened seats. Much R&R was done regarding 305's power upgrades over the years on other forums. And why not? The 265-400's will all respond to well thought out combinations. Reasonable expectations should be at the forefront.
Old 01-26-2019, 07:43 PM   #16
MikeB
MikeB's Avatar
Re: 307 engine
Good to see no heated discussions here!
Assuming choice of heads, I'd take a 307 with its 3-7/8" bore before the very small bore 305 (smaller than a 265). I just read that a long stoke/small bore engine will produce fewer remissions, which was no doubt a reason for the 305's existence.
As mentioned earlier, the 307 will respond to 1.94/1.50 valves, whereas the 305 not necessarily, even with a "fly cut" at the top of the cylinder for valve clearance. Also, the 307 has lower piston speed at any RPM, which reduces friction.
But, hey, I'm not biased.
Mike
Old 01-26-2019, 09:06 PM   #17
hatzie
Moderator
hatzie's Avatar
Re: 307 engine
Use the 305 cylinder heads on the 307 they have 1.84 intake valves 58cc combustion Chambers and hardened valve seats.
The increase in compression from the smaller combustion Chambers will be offset by the fact that you're still using the stock flat top pistons so you won't get a lot of detonation if any.
Use a 1ton quadrajet on a Edelbrock spreadbore performer Dual plane intake and use a vacuum advance hei distributor.
There are several good cams that should work well with that combo. It'll be a much better behaved truck engine than the 305.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-26-2019, 11:41 PM   #18
68post
Re: 307 engine
This is the recipe I had in mind if I do use my leftover 307 that has been here for 25 yrs, and install into my '85 C20. I have the smallest Voodoo cam for it too, 2 sets 305 heads. Would love to use the TBI swirlies and mill for 10.5 compression. This would be aimed toward mileage and what torque we can muster.
Tim K.
