01-06-2019, 12:07 PM | #1 |
NP205 shifter lever
just got done rebuilding my 205, and did a test fit of the shifter and it wobbles side to side a lot. Does anybody have a source for a shifter lever bushing kit that comes with a new shouldered bolt? Not going twin stick.
01-06-2019, 04:45 PM | #2 |
Re: NP205 shifter lever
Offroaddesign.com
01-07-2019, 02:51 PM | #3 |
Two places I know of to get a shoulder bolt. Caveat is, they are both 9/16 thread. The shoulder is nice to bottom out and tighten and have appropriate space to let the lever move freely.
If you have 9/16 and can use the bolts here's the low down. You may need to get your lever cleanly machined to accept the greasable bolt. I used the JB bolt with bronzed flange bearings. Same as what JB ships, except with a flange. I pressed in the bushings, they were tight. Once in, the pressure on the bushings caused the shoulder bolt to be too tight and not fit. I put a sand drum on my dremel and carefully swilled it around inside until I got the bolt in with a snug fit. The new bolt with bushings work nicely. I still got plenty of rattling from my linkage. I had to pull or push the shift lever snug to stop the rattling/ringing. I got some spring washers and fashioned some washers out of a plastic milk jug. I used a combination of: spring washers, rubber washers and plastic washers to fill all the gaps where the linkage is cotter pinned together. My setup is now quiet and shifts like new. Good luck! https://jb-custom-fabrication.myshop...lt-upgrade-kit http://jkwoffroad.com/offroadproducts.php j
White K20 |
01-21-2019, 07:35 PM | #4 |
I've got some late model shifters with the rubber insulator built into the shifter. I have them on Ebay. Let me know if they work for you.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
01-21-2019, 08:13 PM | #5 | |
4x4k30 if trouble was money i would have plenty |
01-21-2019, 08:31 PM | #6 |
just a heads up offroad design twin and tripple stick kits come with poly bushings in them to mimic the rubber ones from the last few years .
i have had ord levers for years with zero rattles and clanging around . used mine a few times today plowing and driving . smooth and clean fell . so if you dont want stock and wish to have more control of t-case options look them up .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-22-2019, 12:43 PM | #7 | |
j
White K20 |
01-22-2019, 04:04 PM | #8 |
just a fyi : you do know holding pressure / tension on the lever will wear the shift fork pad a lot faster and maybe even the lock ring the fork moves . this later on will give you tons of play in the system .
01-23-2019, 01:47 AM | #9 |
On the original shifters, I'm pretty sure they used wave washers to limit the side to side slop. I actually have a shifter and bolt that still has one WW in the next room...
I'd try the little drawers of hardware at the hardware store. https://www.google.com/search?hl=en&...31.zt60EeRiG3M |
