Old 01-28-2019, 02:26 PM   #1
dave`12
dave`12's Avatar
Horn question
I had my horn apart several months. I think I put it back together correctly, but it does not work.
I think i have all the parts - see picture
the turn signals and canceler work.
when i press the horn, it moves in properly - i hear a clicking (the flat metal plate).
the white piece with the pin in it seems correct, has a spring that seems to work as it should
when i touch the metal cup to the shaft (like the crescent wrench in the picture), the horn sounds. The horn also sounds if i slide around the flat plate (picture) to the shaft.
I also got the horn to sound once by pressing hard on the steering wheel itself, but that has not repeated.
any ideas what is going on?
Thanx!
1967 C-10 4-speed, 350v8
dave`12 is offline   Reply With Quote
Old 01-28-2019, 02:55 PM   #2
kazoocruiser
Re: Horn question
From your picture, it looks like there is a lot of corrosion on the flex plate. The inner circle has to make a good solid ground on the steering shaft.
I don't know what's up with the horn honking when you jump out the center of the shaft with the cup. That part is isolated from ground with the plastic ring.
Have you tried sanding off the portion of the steering shaft where the flex plate plate would make contact with it?
I wouldn't admit it if I installed the flex plate upside down, but I've done it on the way to getting things to work.
kazoocruiser is offline   Reply With Quote
Old 01-28-2019, 02:57 PM   #3
rpmerf
rpmerf's Avatar
Re: Horn question
Check the fuses.
Get a multimeter or test light and follow it down the line. See where you have power and where you don't.
http://outintheshop.com/faq/wiring/w...s/image002.jpg
http://outintheshop.com/faq/wiring/w...s/image003.jpg
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 01-28-2019, 02:59 PM   #4
dave`12
dave`12's Avatar
Re: Horn question
Thanx for response. I will try some sanding on the flex plate. It's not upside down because I can see the marks (in picture) where it has been riding on the cup, but it's the kind of mistake I generally make, so good advice.
Old 01-28-2019, 08:11 PM   #5
dmjlambert
dmjlambert's Avatar
Re: Horn question
That flex plate has a round hole in the middle. The edge of that metal hole contacts the steering wheel hub right next to the nut to make the horn honk. So make sure the under side of the flex plate, particularly the edge of that hole, is clean and bare metal, and make sure the hub of the steering wheel is bare clean metal where that edge comes in contact. The steering column shaft that sticks up through the steering wheel also needs good metal to metal contact with the steering wheel. I mention this because it looks like you have a grey paint and/or primer on that steering wheel.
Old 01-28-2019, 08:20 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Horn question
Everything in there needs to be clean, clean, clean. The disk, the spring loaded pins, the underside of the canceling cam, and the inside of the steering wheel, (except the edge where the outside of the metal disk sits). Really important.
Lockdoc
Leon
Old 01-29-2019, 03:16 PM   #7
dave`12
dave`12's Avatar
Re: Horn question
I think you have nailed it, something has got paint on it. (sanding the parts did not help).
Here is a picture of the steering wheel. I did not think any part of this needed to be clean, am I wrong?
Maybe the circle around the hole for the shaft? How about the inside part with the ridges that catch the steering shaft?
Got it to honk again while pressing on the steering wheel rim!
thanx
Old 01-29-2019, 03:29 PM   #8
kazoocruiser
Re: Horn question
There's your problem. . .
The area I circled all has to be sanded to remove the paint.
Name:  IMG_6929 (1)_LI.jpg
Old 01-29-2019, 03:30 PM   #9
dave`12
dave`12's Avatar
Re: Horn question
Ha, that did it, paint on the wheel itself.
Once again you guys have saved me from myself.
thanx much!
