A Arm Conversion
Evening All
1972 c10 thinking about rebuilding my complete front suspension ive got all new front disc brake parts for the 1972 probably take off a arms and rebuild as well as the complete front end parts, moog more than likely are the 1973 thru 1987 a arms and suspension any better do i need to use the 1973-1987 spindles and brakes or can i stay with my 1972 equipment is it worth changing over or leave as is if i do change over and need alignment do i go 1972 or 1973 thru 1987 Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
Re: A Arm Conversion
Not sure I can answer your question. I've got a 67 that I put an 83 front suspension on - crossmember and all. It's not on the road yet but I plan to align it to the 83 specs. I would think, since all parts 72(?) and up - rubber bushings - are basically interchangeable, that the alignment specs would be the same. But again, really don't know.
What I really wanted to say is congrats on the cancer!! Good for you. Hang in there and whoop it's ass!!!
I read your thread the day it came out and was puzzled as to why you would want to change the A arms. Is there a benefit that you have heard about?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod. |
Thank You HooperCa
I’m probably going to stay with the 72 components after all. Had a chance awhile back to get a whole front end from an 1984. But it’s gone now Might go with the cpp a arms and moog susp parts might have to get new springs Thanks for the replies
| Bookmarks |
