Old 01-31-2019, 10:44 PM   #1
prin
prin's Avatar
front spring issues
I don't drive my truck often. But, I have noticed in the past couple months that the front tires are scrubbing when I turn. This has never happened before. So it looks like my springs have sagged a little. What are some options before I buy new springs?
prin is offline   Reply With Quote
Old 01-31-2019, 11:55 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: front spring issues
I'm no front end man but if they are scrubbing I would say that would be more alignment. Have you checked the tie rods and cross link to see if they might be bent? Or the shims between the upper "A" arms and the frame to see if any are missing.
LockDoc
Leon
Old 02-01-2019, 01:27 PM   #3
rcazwillis
What do you mean by scrubbing? Tires rubbing somewhere or an alignment issue?
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-02-2019, 12:44 AM   #4
prin
prin's Avatar
Yes, the tire are scrubbing especially when you turn them. It is on the upper fender. I really don't think that it is an alignment issue
Old 02-02-2019, 01:13 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
What size wheels and tires are you running?
'68OrangeSunshine is online now   Reply With Quote
Old 02-02-2019, 11:51 AM   #6
LockDoc
LockDoc's Avatar
That's not scrubbing, that is just rubbing on sheet metal parts. Scrubbing is when the problem is actually wearing off the tread on the tire.
From Wikipedia:
What causes tire scrub?
What are the significant causes of excessive tire wear. Uneven or accelerated tire wear can be caused by wheel misalignment, worn suspension and steering components, and/or improper tire inflation. The most critical alignment angle with respect to tire wear is toe. Camber is also important and can be affected by caster ...
If they are rubbing then yes, the springs are suspect.....
LockDoc
Leon
Old 02-02-2019, 12:03 PM   #7
Boog
laying low
Boog's Avatar
As usual some pics of the truck and affected area would help diagnose it.
Boog
