Re: LS swap to a 72 K5
I will check out the Dirty Dingo mounting kit.
It is rolling chassis now and it has a 4" lift kit. A friend of mine is putting a 6.2 (i think) in a 60/70 carryall 2WD. I am not sure what mounts he used but without measuring the motor looks both high and deep in the engine bay. He is using the 4L80. He had to do some trim work on the frame on the passenger side for the exhaust manifolds. He will need to do something to mount the AC compressor. I bought a 2003 2500HD with a 6.0. I should have everything to make it go but I want to set the engine and do all the modifications/trimming before I disassmeble and re-build the engine. The hardest part may end up being just getting started. Scott |
| Bookmarks |
