Re: About to order wheels for my 67, backspacing?
im running ridlers at the sizes your looking at on a 70 fleetside with the wider of the 12 bolt rear ends. 57" backing plate to backing plate
running 275/40/20... i think there is enough room for 295/40 but again this is the wider rear end. axle width is 55.5 wide with 30.5 long axles on the narrow rear end. earlier rear end axle width is 57 wide with 31 5/16 long axles on the wider rear end. later rear end this site is helpful in seeing sidewall measurements and what fits on rims https://www.rimsntires.com/specspro.jsp |
#2 | |
Up front I'm running ridetech strongarms and cpp drop spindles/big disc package so everything should be fine up there. The 245/45s should buy me a little bit of extra room but still be able to have some sidewall. I'll have to make some spacers for the rear but shouldn't be a big deal. Once I get them in I'll get some measurements to try to get everything where it needs to be. Thanks a lot for the feedback! |
This is the width and height when mounted of a 20x10 5.5bs with a 295/40/20 Nitto 555 on a rider 650 wheel. The bottom looks crooked but its to show how I took the measurements. Width on rim is 11 9/16" height is actually a little over 28 3/4"
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Alright cool, we should be good then. My only complaint is one backspace option for these.
Just an update for if it helps anyone in the future. Currie sells two width crate rear ends. I have the 67-70early 62-1/8" wide one (late 70-72 crate rear is 63-5/8 wide between mounting surfaces), otherwise I would probably be spot on in the backspace ridler offers for these with 5x5 pattern. I'm going to machine some 3/4" spacers and it should give me about 1/2" inner wheel well clearance per side. That would put me exactly 63 5/8" anyway, so numbers work out fine. I wish I could have gotten a 4.75" backspace instead and gotten a little more dish in the rear, but these will do fine until I order some forgelines later in the build.
I like them. I'm back and forth on if I should go with a 35 AR rear tire instead of a 40, but it's fine for now. I had 18x8 up front and 19x10 rear before, so the front looks quite a bit bigger. Final sizes are: Ridler 695 series 20x8.5 4.75" backspace with 245/45r20 up front, 20x10 5.5" backspace with 295/40r20 in rear (nitto 555) |
