Old 02-02-2019, 09:29 PM   #1
jcwren
Glove compartment installation question
Does the glove box cardboard go inside or outside the dash frame? In the picture, is this right or wrong?
The joys of having things you didn't take apart yourself...
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 02-02-2019, 10:20 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Glove compartment installation question
That would be correct.
LockDoc
Leon
Old 02-02-2019, 10:56 PM   #3
Rods
Rods's Avatar
All the inserts I’ve done I put them under the dash with the hinge on top of the grill and the screws would go through the hinge then the dash and last into the glove box insert. You shouldn’t see the edge of the insert at all. That’s my two cents.
Rods is offline   Reply With Quote
Old 02-02-2019, 11:33 PM   #4
jcwren
I know the top and side holes in the glove box have clips for the screws to thread into. I don't think there are clips on those bottom holes. Did you just let the screws go through, or do something else to provide support on the bottom of the cardboard?
I think it would look cleaner the way you're describing.
1971 Dodge Dart
Old 02-03-2019, 08:42 AM   #5
Rods
Rods's Avatar
Some of the inserts have the same type fastener you’ve described on the side holes also at the bottom holes.
Ive also seen others that supply you with clip type fasteners that you put over the cardboard insert and you line up with the screw holes.
Ive also seen them with the little flat clips that that have the sharp corner point’s to press into the cardboarded inserts for the screws.
They should have been in the same baggy that the screws came in. But if you dont have them you can easil purchase them at the hardware store.
Old 02-04-2019, 09:33 PM   #6
chiefcfd
chiefcfd's Avatar
On another note, what color is that interior?
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 02-04-2019, 10:30 PM   #7
jcwren
Medium bronze (paint code 522).
1971 Dodge Dart
