Old 02-03-2019, 06:31 PM   #7
jdl71
jdl71's Avatar
Re: '65 Water temp gauge not warning lights
Originally Posted by jmcap View Post
Hey Guys,
I want to return to the old school look of the original dash cluster (that I have available to me ) rather than the aftermarket gauges in an after market dash cluster the PO has installed.
Particularly as it applies to wiring the Water Temp Gauge. The wiring diagrams all show hot and cold lights rather than a needle gauge. I know I need to change out the engine block sensor to the older style. The rear of the gauge has two contact points: one to the sensor and the other to ??
Your help is always appreciated,
John
The light cluster actually has 4. One pink for each light and one green (dark and light) for each light. Pretty sure they are two different connectors so you should be able to use which ever one you choose to plug into the gauge cluster and leave the other unhooked.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
