Old 02-04-2019, 05:23 PM   #1
FAKKY
Fuel Line
6.0 LQ4 and stock everything in a 57 panel truck.
Whats everyone generally doing for fuel line and fittings ?
Im guessing for 300HP that -6AN (3/8) together with a few adapter firttings like
3/8 line is the inlet
https://www.summitracing.com/parts/rus-644123
5/16 is the return
https://www.summitracing.com/parts/rus-644113
Seems to be a huge variation in lines and fittings - any recommendations from what you used on your project ?
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 02-04-2019, 05:50 PM   #2
Daaaanz67
Re: Fuel Line
You got it. Also used the russel hose.
Daaaanz67 is offline   Reply With Quote
Old 02-04-2019, 08:05 PM   #3
FAKKY
Re: Fuel Line
Thanks.
Just wondering what the difference is mainly.
$59
https://www.ebay.com/itm/Braided-3-8...jf:rk:128:pf:0
$240 with a $40 fuel filter/reg
https://www.summitracing.com/parts/t...it45/overview/
Old 02-04-2019, 08:54 PM   #4
mongocanfly
mongocanfly's Avatar
Re: Fuel Line
I used all summit brand -6an hose and fittings on mine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-04-2019, 09:17 PM   #5
FAKKY
Re: Fuel Line
Anyone use hardline for main run ???
Two good sites outside of summit. One is a vendor here.
http://www.anfittingsdirect.com/
https://hotrodfuelhose.com
Old 02-04-2019, 11:00 PM   #6
72MARIO
72MARIO's Avatar
Re: Fuel Line
I used AN fittings from fuel rail down the transmission to the frame. From there i used dorman nylon fuel line and stock ptc gm fitting. Cheap quality lines
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-04-2019, 11:05 PM   #7
72MARIO
72MARIO's Avatar
Re: Fuel Line
Check out these fittings GM fuel.line to hose end all in one piece
http://www.russellperformance.com/mc...injected.shtml
2005 TAHOE DD
Old 02-04-2019, 11:18 PM   #8
mongocanfly
Re: Fuel Line
ive seen several builds here where the owner is using the plastic hardline....also some use metal lines...MP&C is using all stainless tube on the wagon...its just much easier on me to run the -6 stainless flex....being flexible its easier to route it around stuff...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-05-2019, 01:52 AM   #9
First c10
First c10's Avatar
Re: Fuel Line
I used -6 an from my tank to the frame rail where I mounted the regulator/filter then hard line up to the fuel rail and used another short -6 an line. I even covered my hard line with DEI protective sleeve near the exhaust.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-05-2019, 08:03 AM   #10
bigmoe
bigmoe's Avatar
Re: Fuel Line
Originally Posted by FAKKY View Post
Thanks.
$59
Wow that's quite a price difference.
bigmoe is offline   Reply With Quote
Old 02-05-2019, 08:27 AM   #11
77c10bowtie
77c10bowtie's Avatar
Re: Fuel Line
Thanks.
$59
try not to buy a "kit" you can piece it all together from summit for less than what that kit costs. i also wouldn't buy that cheap chineese crap from ebay but that's me.
77c10bowtie is offline   Reply With Quote
Old 02-05-2019, 09:21 AM   #12
STICKBNDER
Re: Fuel Line
make sure to use the "PTFE" hose. it holds up better than other stainless hoses
STICKBNDER is offline   Reply With Quote
Old 02-05-2019, 09:33 AM   #13
FAKKY
Re: Fuel Line
Curious - how come ? - couldnt you have used 3/8 [6AN] dorman nylon all the way with AN fittings still ? AN to barb for example.
thanks
Thanks I'll look up that build - but think Im abandoning the idea - just doing brake hardlines and flaring and just got me thinking
In a build thread ? Pics ?
Yup.
Im thinking about going the PTFE route on the link I sent above ...... but was curious to find out what others were doing and happy with.
thanks
So .... seems like I have a returnless fuel rail. Pic.
I think its simple enough ..... basically fuel pump out to corvette regulator which pressurises to ~58 psi as it passes through to fuel rail. If it sees pressure build it dumps back to the tank vi the return at the regulator.
What confuses me a little is ....
1) Some threads where they say in a returnless system fuel is controlled by ECM as well ...... but that wont happen here right ?
2) Discussions where the FPR in a OEM setup is either on nthe tank or in the fuel rail itself. Not sure. Obviously I wont have 1 in the tank with my tanksinc walbro pump ...... but will have the regulator on the truck trail somewhere.
https://www.summitracing.com/parts/CMB-03-0263
Anyone clarify 1+ 2 a bit better for me ? Probably misunderstanding
Old 02-05-2019, 10:30 AM   #14
First c10
First c10's Avatar
Re: Fuel Line
Page 15 post 369/370
http://67-72chevytrucks.com/vboard/s...659275&page=15
GO GO!!!
Old 02-05-2019, 03:14 PM   #15
mongocanfly
Re: Fuel Line
I always thought when the pump built up pressure and deadheaded that it shut off...but Eric (ls1nova)says the ecm turns the pump on for x number of seconds when the switch is turned on and then shuts it off till you crank....so I'm going with what he said...best I can tell your rail is returnless...
1vs2...on a returnless rail system the fpr is in the tank and will have a single fuel line to the engine
On a return rail system the fpr is at the fuel rail and the engine will have 2 fuel lines from the tank to the
rail...one pressure and one return..
If your using a intank pump with no bypass then you'll need to run the vett style reg ...and when plumbing it up keep In mind the pressure side is the outer fitting....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-05-2019, 03:33 PM   #16
FAKKY
Re: Fuel Line
Ill be running this pump (Pa-4)
http://www.tanksinc.com/index.cfm/pa...rod/prd609.htm
and this filter/regulator on the frame
So the plumbing side is failry self evident (appreciate the info though) ...... but there is no ECM control of the pump. Thats the part that throws me.
So anything need to be disabled etc in ECM ?
Basically just lose that funcionaility that ls1nova talks about above ? It will pump on power on and just self regulate at ~58psi.
Old 02-05-2019, 03:39 PM   #17
mongocanfly
Re: Fuel Line
On mine I used a psi harness that came with all the wiring and a fuse block...in the fuse block is where my pump gets its power from...this is controlled by the ecm...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-05-2019, 03:45 PM   #18
FAKKY
Re: Fuel Line
*doh* - didnt think of it like that - was thinking of it as a subharness run that goes to the pump - like a special connector etc
Old 02-05-2019, 04:54 PM   #19
FAKKY
Re: Fuel Line
Thanks guys !!
Thanks mongocanfly
Old 02-05-2019, 07:53 PM   #20
ls1nova71
ls1nova71's Avatar
Re: Fuel Line
I think you're just overthinking this. The PCM will turn the pump on, but it wont regulate it in any way. How the truck the engine came out of was plumbed is irrelevant if you're plumbing it like an early 2000's Corvette, which is the easiest way to do it , so that's why swaps are done that way.Plumb the Vette filter and let the PCM turn the pump on.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-05-2019, 10:35 PM   #21
Bret B
Re: Fuel Line
Mongocanfly - that picture just helped me tons!!! I could figure out where the heck that fitting went, but that picture just cleared it up.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 02-05-2019, 11:32 PM   #22
FAKKY
Re: Fuel Line
Yes your right. I just didnt think of the pump being powered on by PCM. Thought it would be a straight IGN ON/OFF deal on an aftermarket pump ..... just didnt cross my mind.
Old 02-06-2019, 09:50 AM   #23
FAKKY
Re: Fuel Line
What are most people doing with the fuel purge solenoid.
Blockoff ?
I'll have two vents on fuel tank (1 to above fuel fill intake and other in tank with line vent routed above frame).
Not sure if I need a 3rd ...... but then again ......
Old 02-06-2019, 11:25 AM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel Line
They sell delete plates. I just put a bolt through a teardrop piece of metal, welded it, and rounded off the threading to make a nub.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-06-2019, 11:27 AM   #25
ls1nova71
ls1nova71's Avatar
Re: Fuel Line
I just take the hose off of it and leave it in. If it isn't bad, and they usually aren't, it will be closed until power is applied to it, so it acts like a block off. It's under the Vortec cover so you wont see it.
