Old 02-04-2019, 03:39 PM   #1
GTS61
New battery and new alternator-DEAD
I have a 1961 GMC pickup with a 305 V6. I installed a new battery and a new alternator. Started it up and watched my volt gauge go from 12 to 0. Anyone have any idea’s why this would happen? Thanks a lot!!
GTS61 is offline   Reply With Quote
Old 02-04-2019, 05:03 PM   #2
straight6chevyguy
straight6chevyguy's Avatar
Re: New battery and new alternator-DEAD
Are you using the original style voltage regulator or are you using a newer alternator with an internal regulator?
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-04-2019, 06:02 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I once installed an internal regulated alternator in a truck that used an external regulated alternator. It worked. Until I got to the 1st car show I ever went to and there I was stuck. Yep, ya live and learn. Of course this was way before the internet.
Old 02-04-2019, 08:00 PM   #4
GTS61
Hahahaha! I’m using internal one. I just found the problem. A exposed wire was grounding out everything but thanks for replying.
Old 02-05-2019, 06:15 PM   #5
forestb
forestb's Avatar
Sorry to hijack this thread but do I need to run a ground if I have an internally regulated one wire alternator?
forestb is offline   Reply With Quote
Old 02-06-2019, 04:39 AM   #6
vince1
I think you want continuity from the alternator case to the battery negative. Probably you already have that through various grounds.
vince1 is offline   Reply With Quote
