Old 02-06-2019, 08:59 PM   #1
SKR
Re: 4L80E - what do I need to salvage from a donor truck?
Originally Posted by cruizin01 View Post
I bent up my own shift rod for my 4L80E. It works with the stock column. Your stand alone controller will have all the wiring needed. If the 92 as its own trans cooler I would salvage that if you can. There's some info in my build if you want. Or PM me.
I had a look at your thread. Looks like you're doing a lot of the things I've done, or want to do. I'm running a Sniper as well. Right now I'm using whatever distributor was on the motor, but I want to change that out for the Holley one that talks to the Sniper. With a 19 gallon tank and a big block I figure I might as well do everything I can to help get a little better mileage. Funny you went Dakota Digital too - that's what I might end up doing. It's a lot of money, but so is converting the speedo signal from electric to mechanical.
Hopefully it gets warm here soon. I'd like to put a few more miles on the 92 just to make sure everything's good, and then start ripping it apart. I want everything in by April 1. Not sure if that's a deadline I can hit or not. Probably not.
2007 GMC 2500 CCSB LBZ
1991 GMC 1500 RCSB 350
1981 GMC Street Coupe RCSB 454
SKR is offline   Reply With Quote
Old 02-06-2019, 10:28 PM   #2
cruizin01
Yeah, I hadn't planned on all of this but its always one thing after another and you keep replacing/upgrading stuff as you go. Im pretty happy with everything so far. Lots of wiring to make everything work together but Im hoping it makes this old turd reliable and fun to drive. Let me know if you need help with anything.
'78 C10 Build
cruizin01 is offline   Reply With Quote
