Other uses for choke hole in bezel?
I no longer need a choke but I am left with the hole in my instrument cluster bezel. Rather than plug it with a choke delete, I would like to actually use the hole for something. Maybe some sort of switch, light, volume knob for my amps, or whatever.
Looking for some creative ideas, what have you guys done with this empty hole? |
![]() Join Date: Dec 2012
Re: Other uses for choke hole in bezel?
I've installed the billet knobs on my switches - and rather than leave the choke hole open, I took another Headlight switch and installed it there, purely for looks..... I'll see if I have a pic...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
The Headlight and wiper switches match as well..
Thanks Ned, if I don't come up with something, I will probably put the choke knob back in. I would like to put some kind of engine disable switch connected to the choke knob or something.
I've always liked the idea of the ignition switch there. Just have to figure out how to mount it.
My dash has a GM blocker plug for that hole in dash, I like the look if you can find one
![]() Join Date: Aug 2017
A cigarette lighter for charging stuff or a radar detector?
![]() Join Date: Feb 2014
I was thinking if I had a 67-68 with a LS is to feed the ground for the fuel pump relay through a wiper switch in the choke opening or manual on for the the cooling fans. Hmmmm the possibilities
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
Well, not "choke hole"... how about cigarette lighter hole?
I put a USB connection for phone/Ipod in mine. Complete with little black plastic cover. You could do the same, or a light, or??? (If you can enlarge the picture, you can see it here...) Just be creative. Best of luck! |
Wiper switch to control whatever your needs are or just a dummy
Nitrous switch!
![]() Join Date: Aug 2015
![]() Join Date: Dec 2006
If it was mine, I'd add a very bright red temperature warning light. With the gauge only, I have missed two very bad overheating events in the last couple of months that almost cost me big. So I'm looking at a place for the lamp and a way to set it up.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#15 |
![]() Join Date: Mar 2003
Yep, wiper switch as an anti-theft
