Old 02-08-2019, 10:24 PM   #626
Kronald_70GMC
Kronald_70GMC's Avatar
Re: 67 GMC super custom build
Originally Posted by chewychevy67 View Post
Complete
That's pretty cool what you got going on there! I like it. Colour looks way better with the illumination on.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 02-08-2019, 10:48 PM   #627
chewychevy67
When the lights are on it looks pretty much spot on. Now that I have it done I may not bother with trying to make it perfect. I have it straight now and I may not get it that good again.
chewychevy67 is offline   Reply With Quote
Old 02-08-2019, 11:15 PM   #628
Kronald_70GMC
I'd leave it too. Looks good
Kyle
IG: kyle_ronald
Old 02-22-2019, 01:18 AM   #629
chewychevy67
Since I was into the gauges I thought I wanted the clock in the dash to have the same font as the gauges so I did this. Now it will look factory even though it's not.
Old 02-23-2019, 02:36 PM   #630
chewychevy67
I bought these red 72 door panelsfrom a big truck and I'm Thinking about using them. I would mount my switches from the underside ( 64 cadillac style switches) on the flat edge of the panel so I need to have these squares for the switches cut out by a machine to make sure they are sharply cut and square. I will put my door lock switch where the window crank used to be and cover the wood grain piece with vinyl.
Old 02-23-2019, 10:56 PM   #631
chewychevy67
I added green led bulbs to my dash pieces. I love the way this looks. Looks a bit clearer in person. There not too bright but It's just too bad they don't dim like factory intended them to. I also took a pic with white ones. They don't seem as bright.
Old 02-24-2019, 12:43 AM   #632
Kronald_70GMC
That's weird that they don't dim. I have leds in my 04 dome light and they dim with everything else.
Kyle
IG: kyle_ronald
Old 02-24-2019, 12:45 AM   #633
chewychevy67
I actually never tried but the seller said that they won't.
Old 02-24-2019, 02:16 AM   #634
67 Burb
67 Burb's Avatar
The instrument lights dimmer in a '67 GM truck was designed to dim a higher current draw than what the LED's draw. Mine in the Burb dim slightly and then go out.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 03-04-2019, 01:59 PM   #635
chewychevy67
I opted to keep the a.i.r. Injection on the 327 but I devained the pump so it not operational. Today I figured out how to plug the manifold holes without ever knowing. The hole is the perfect size to tap for 1/8" pipe thread. I took 8 1/8" brass Allen key plugs and put them in. Just tap it from the front so it seats at the lowest point in the hole and then it's plugged. Now put the air tubes on and done. Looks completely functional and you can go back to making it functional if you ever wanted to.
Old 03-14-2019, 02:08 PM   #636
chewychevy67
Did my power windows and locks switches in the 72 door panels today. I like this much better and looks cleaner. The woodgrain will be covered with bright red vinyl to match the panel.
Old 03-14-2019, 02:26 PM   #637
Kronald_70GMC
Looks good. I was just thinking, why is there 4 switches for windows then remembered, oh yeah power vent windows. So are the two front ones for the vents and the back two for the doors? Also does the passenger have control over their vent window or just the driver?
Kyle
IG: kyle_ronald
Old 03-14-2019, 02:29 PM   #638
chewychevy67
Yes the passenger will be able to control both for the passenger door. . That a job for this afternoon. The sideways switch is for vents and the other horizontal one is for door glass.
Old 03-14-2019, 02:59 PM   #639
Wide Open
A 4000 pound truck with 2000 pounds in options
Your truck is going to be amazing when you have it finished!
Keep up the great work.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 03-14-2019, 04:15 PM   #640
chewychevy67
Yeah she is full of extra weight that's for sure. Here is the passenger side.
Old 03-14-2019, 07:06 PM   #641
Kronald_70GMC
Awesome! Love it!
Kyle
IG: kyle_ronald
Old 04-03-2019, 01:39 PM   #642
chewychevy67
I got a set of Nos left and right dual exhaust mufflers parts 3861811 and 3861812. They have 2.5" inlets and 2.0" outlets. I think everything gm put out had 2.0" outlets in these years. They are correct for 64 327 with high performance (not special high performance). The engine I'm using is a 64 327 300hp so I may use them. My original truck motor will stay on the stand. Not too much original about this truck any more anyways.
Old 04-03-2019, 01:51 PM   #643
chewychevy67
The 300hp used an afb carb from factory and I wanted to keep it looking stock with a 4jet. Now since my original 4jet was small and was really for the original 220hp engine I had a new 4gc custom built for my new built 327 specs and added the turbo 400 kick down throttle arm to this carb. It has the base of the 409 340hp carb to match the 300hp 327 intake design. It's not as stout as the 409 carb though. It will be more suited for a small Cid engine. I'm going to send it out to get the body recolored soon. I may use the original 2.5" exhaust manifolds that were on the 300hp engine and not put the smog pieces on the engine.
Old 04-03-2019, 02:12 PM   #644
chewychevy67
The gm page shows what the mufflers are correct for. I wonder how quiet and restrictive these will be. There heavy. Wish they sound like a turbo muffler.
Old 04-03-2019, 02:39 PM   #645
Sloonz
So many interesting details on your build! Fantastic work. Sub'd...
Sloonz is offline   Reply With Quote
Old 04-10-2019, 06:51 PM   #646
clay68c10
clay68c10's Avatar
Great build you’re doing! I just finished reading all of it over the past couple days.
You will really like the Twilight Sentinel, it is one of my favorite things about my Cadillac. The caddy has an additional post-shut off functionality, if you leave a turn signal on, it turns on that side’s cornering light also. Not sure how you can use that, but you’re pretty creative.
The Guide-matic is cool too, but the road signs are very reflective now vs the 60s. The lights tend to dim when the signs reflect back at you. Otherwise, it is a very slick system and works great as designed.
I never thought to join a switch pitch 400 and a Gear Vendors, what a great combination. I’ll take that over a 700R4 any day.
Keep after it!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-11-2019, 12:36 AM   #647
chewychevy67
That's interesting how the signs have changed. I never thought of that. Totally makes sense. I have thought about cornering lights as my turn signal switch has the wiring. I would like to somehow put a lens in the front of the 67 68 body mouldings so it doesn't disturb the body lines but not sure if I'll get that crazy.
Old 04-11-2019, 11:13 AM   #648
chewychevy67
All machined and ready for some guts. Heads are done already too!
Old 04-11-2019, 12:57 PM   #649
67_C-30
I have a radical idea!
67_C-30's Avatar
Looks great!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-03-2019, 12:47 PM   #650
chewychevy67
I bought a transmission oil cooler for the truck. With the variable pitch converter I wanted to make sure it won't get too hot. It's made for 1971 mopar cars. I like that it has thread fittings instead of hose and clamps. Going to mount it in front of the air conditioning condenser.
