![]() Join Date: Nov 2018
Brake job 101
Hello
Took off the front tire and this is what I found. I guess torching front hub off is easier than removing the rivets that hold brake drum in place. ![]() Last edited by Blk63vette; 02-02-2019 at 11:30 PM. |
![]() Join Date: Sep 2006
Re: Brake job 101
It took me a while to figure out the picture. Looked like the hub was rusted but after looking, it seems that is part of the drum that is rusted onto the hub. If you remove the hub you should be able to press the studs out and get that apart or the part is just junk and might need to find another hub which would probably be a lot easier.
You could also remove the hub and soak it in penetrating oil for a few days. More then likely it can't be save but you will never know unless you try.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Re: Brake job 101
Hello
I think the hub can be used. It had sat in a Texas barn since 1987. I think when the guy I bought it from moved the truck this side was locked up so it only natural to torch the drum off to get the car rolling again to get it In on the trailer. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Brake job 101
Wow , I'd go over the whole truck now to see what else he did?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
But Found Her 25yrs Later!
Re: Brake job 101
Have you considered just swapping it all out for 73-87 power disc brakes?
Re: Brake job 101
This truck will need everything. This gonna take a while to get it road worthy again. This has been sitting in a field in Texas since 1987. Everything is a mess.
Re: Brake job 101
This truck will need everything. This gonna take a while to get it road worthy again. This has been sitting in a field in Texas since 1987. Everything is a mess. Any help would greatly aporecitated. This took my 14 + years to do a 1963 Corvette
Re: Brake job 101
Here is my 1963 Corvette
Re: Brake job 101
![]() Join Date: Dec 2018
Re: Brake job 101
One sharp vette!
I like the truck to by the way!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
Re: Brake job 101
Lacking any knowledge on 64-66 why is the A/C compressor and alternator switched sides?
![]() Join Date: Oct 2012
Re: Brake job 101
Possibly later model accessories and or engine. I have a '74 350 in my 66, alternator is on the right. Same with my '85, alt on rt, a/c on left.
#13 | |
Re: Brake job 101
Yes they are! Apparently the previous owner decided that he was going to use newer parts to replace worn out ones? So, he has cobbled up the wiring harness and none of it makes any sense. He also put on a long neck water pump and new style pulleys that do not line up. The owner died then it sat out on a farm in Texas for over 30 years Good news I bought correct pulleys and brackets and compressor to put them no back original. Any pictures of original ac set up greatly appreciated Last edited by Blk63vette; 02-04-2019 at 10:38 PM. |
60-66 Nut
Re: Brake job 101
That accessory drive configuration is '69+ car and '73+ truck. Typically when an engine is swapped, 90% of the people leave that style on the engine rather than change to the factory correct style.
#15 |
![]() Join Date: Jan 2011
Re: Brake job 101
Nice truck. Yup it will take a while but always worth it when you get your first ride down the road.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#16 | |
Re: Brake job 101
#17 |
Re: Brake job 101
#18 |
Re: Brake job 101
I’m going need something to figure this out for sure. I never seen a truck this vintage with ac before
#19 |
Re: Brake job 101
#20 |
One foot in front of the other
![]() Join Date: Aug 2008
Re: Brake job 101
At least they left the original shroud and radiator hose when they put it back together.
#21 |
Re: Brake job 101
Here is my little remedy for frozen brake drums. Tried and tested many times on 55-57 cars I have drug out of fields. It will turn the drum inside out and twist the shoes into pretzels but it has never been known to fail and gets them rolled up on the trailer.
