Old 02-07-2019, 11:18 PM   #251
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What did you do to your truck today.The 3rd chapter
Thanks!
~Steven
Simi Valley, CA
Old 02-08-2019, 01:47 PM   #252
tdangle
tdangle's Avatar
Update on my new dual snorkel air cleaner. Drove it last night for the first time since putting it on and exactly what I was looking for. Only time you really hear any intake noise is when you are on it with the secondaries open. Otherwise pretty much as quiet as the stock one. And I know the engine is getting as much air as needed now.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-08-2019, 05:37 PM   #253
weq92f
weq92f's Avatar
Killed my exhaust leak...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-08-2019, 06:23 PM   #254
RodnRudy
RodnRudy's Avatar
Got busy and slung some filler on the speaker hole repair, put seam sealer on the door bottom repair, and rattle canned some DupliColor on everything. Paint doesn't match very well but hey she's a driver
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 02-09-2019, 01:44 AM   #255
cornerstone
cornerstone's Avatar
Nice work RodnRudy.... One would never know there was a gaping hope in the door unless you show them.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-10-2019, 07:10 PM   #256
Metaldoc
Metaldoc's Avatar
Originally Posted by tdangle View Post
Never have liked intake noise so I took off the open element air cleaner and the stock single snorkel air cleaner really impacts performance above ~3K so I put a repo dual snorkel air cleaner assembly on. Not sure I like the how it looks.
Dual snorkel made from the two bbl single snorkel.
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 02-10-2019, 09:17 PM   #257
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Over the last few days installed the intake, finished the brake lines. Installed mounts to block, and the engine perches loosely. Installed bumper stops, finished painting heads, installed transmission mount, positioned the frame and lots of prep for tomorrow. We're dropping this and the transmission tomorrow, and not literally.
Bugs me the hoist won't center over the block while it's on the engine stand, legs are in the way. There might be enough room to help support the block using the transmission jack. Either way we'll make it work, so is the plan.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-10-2019, 09:25 PM   #258
bmxbang
Got my front passenger side frame rails cleaned up and coated today finally getting this side about ready to go back together.
bmxbang is offline   Reply With Quote
Old 02-10-2019, 10:04 PM   #259
zicc1835
zicc1835's Avatar
started to mock up the exhaust system today if anyone has used this Kit( Flowmaster American Thunder ) and has some pictures they can share of the install Im going to have to modify the H-pipe to get it between & thru the trailing arm c-member and fab a bracket to hold the exhaust brackets to the shock member
zicc1835 is offline   Reply With Quote
Old 02-12-2019, 12:52 AM   #260
71CHEVYSHORTBED402
Milestone today, we got the engine/trans. installed. It was as a full day. The mounts were a challenge, but one engine perch is nuts where it was, and the other off a 16th. I'll call it better than our earlier work (1993 rebuild). Went smooth with one caveat. We had the torque converter set, but when I got to the point to bolt it up I found the converter must have slipped forward, because it was already flush with the flex plate. It's my understanding that generally you have to pull it forward 1/8" plus to meet the plate. But the converter spun without much effort and bolts went smoothly, so I think we're good. EDIT: Really I don't feel great about that torque converter. Going to disconnect and double check.
These are my boys. The oldest worked with me all day. The truck is his birthright. He doesn't like Ochre. It will grow on him
BTW, if anyone can recommend a water pump and starter for an original 402/400TH build it's appreciated. I'd like a cast iron pump. If it means no other mods and suits an original block to transmission, including the inspection cover then I'd like to upgrade the starter. I think some are smaller and lighter sounds right
Tony
Old 02-12-2019, 10:34 AM   #261
BugzC10
BugzC10's Avatar
Originally Posted by cornerstone View Post
nice work rodnrudy.... One would never know there was a gaping hope in the door unless you show them.
x2
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 02-12-2019, 04:39 PM   #262
hayhauler71
hayhauler71's Avatar
Put new distributor in and some wiring done.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-13-2019, 03:06 PM   #263
Chris_oz
Chris_oz's Avatar
Not done yet, but on the weekend I will be fitting my "Spot Light".
I got a NOS bracket of Ebay and a 6" light, nice old one with the correct length shaft, Ivory colored handle. It has the original GE lamp.
I think it need a new wire, I pick it up this afternoon.
I am not sure where I will wire it from, Maybe through a relay switched from the ignition.
Chris_oz is offline   Reply With Quote
Old 02-14-2019, 11:24 PM   #264
TruDom
first drive since buying and wrenching on it!
took it to get gas... no issues!
TruDom is offline   Reply With Quote
Old 02-15-2019, 10:46 AM   #265
jaros44sr
jaros44sr's Avatar
very impressive engine detail. I sorta have the same setup on my PCV, but was wondering if you used a tube nut to fasten it. Mine has a collar just RTV d keep ing it on
[url=https://flic.kr/p/2dnBcmX]20190215_094812
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 02-15-2019, 11:04 AM   #266
hayhauler71
I used a regular -6 fitting with a nylon insert pushed in the fitting and then installed on pcv and carb. Smoke tested and no leaks. It was a pain and probably 2 hours work grinding on the fitting. Thanks
Fuzzy
Old 02-15-2019, 08:19 PM   #267
RodnRudy
RodnRudy's Avatar
No Pics to show but I finished putting the doors back together with new glass run channels, window regulators, door relays, and whiskers. I'm amazed at the difference, windows are nice and tight now and roll up and down smoooth. And a shout to Randy500 for his spot on instructions on tear down and reassembly of the components.
Phil
Old 02-16-2019, 01:00 PM   #268
MySons68C20
MySons68C20's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
X2 re Randy500.... Good looking repairs there Phil!
MySons68C20 is offline   Reply With Quote
Old 02-16-2019, 02:32 PM   #269
70STOVEBOLT
70STOVEBOLT's Avatar
Got my motor torn down to a short block so I can get the heads rebuilt and replace the iron intake with an aluminum one.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-17-2019, 12:17 AM   #270
66clow
66clow's Avatar
Got a lot done today. Repaired back panel. Finished the door which took way too many days to complete. I thought I was finished numerous times later to find it wasn't straight. Pulled the front and rear glass. Getting closer each day.
66clow is offline   Reply With Quote
Old 02-17-2019, 09:06 AM   #271
zicc1835
zicc1835's Avatar
what motor ? what manifold ? what carb ? im looking to replace my stock manifold on SB stock motor had a 4 barrel holley on it when i purchased the motor thanks just looking for options .....
Old 02-17-2019, 06:33 PM   #272
Metaldoc
Metaldoc's Avatar
It's up on the two stage cribs I made, not too bad lifting it there in two stages.
Old 02-17-2019, 07:06 PM   #273
MySons68C20
Nicely done!
Old 02-17-2019, 08:07 PM   #274
BugzC10
BugzC10's Avatar
Nice work....now that you have er up in the air, what your next plans?....drop tranny, new exhaust?
Old 02-17-2019, 08:37 PM   #275
Metaldoc
Metaldoc's Avatar
I've put about 5000miles on it since bolt off resto so with it up in the air and the suspension is under load. I want to retorque all the bolts, clean, change some fluids, and give it a going over. I have to add some static electricity grounding straps. I'm finishing the wiring to the P/L, P/W and interior light door pins. With the truck being low and me old I'll take any easy way. Maybe some exhaust work.
