Old 02-08-2019, 05:51 PM   #26
ga-stepside
ga-stepside's Avatar
Re: Grinding/Screech from Block
Originally Posted by sick472 View Post
Look at the video at 7 seconds and it looks like the "Eddy" is missing a plug that would normally be used for power brakes. And, again at 29 seconds. AND at 32 seconds...this one is the money shot...I don't see a plug. I hope that's it...easy fix!
I saw the same thing,
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 02-08-2019, 08:40 PM   #27
RhapidFyre
RhapidFyre's Avatar
SOLVED - 5/16th plug in the hole mentioned.
Can anyone explain what that hole is for (I heard power braking?) and if these trucks use that?
RhapidFyre is offline   Reply With Quote
Old 02-08-2019, 08:42 PM   #28
truckster
truckster's Avatar
It's a vacuum port that can be used for a power brake booster. Trucks use it if they have power brakes (vacuum boost).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-08-2019, 09:14 PM   #29
ga-stepside
On the video you have a power brake booster, where do you have the hose from it hooked to now?
1967 C10 Step side
1970 AMX 390
Old 02-08-2019, 09:22 PM   #30
rockyrivermark
Yep. Sounds like a massive vacuum leak
Plug that port on the back of the carb.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 02-08-2019, 10:15 PM   #31
RhapidFyre
RhapidFyre's Avatar
Honestly I didn't think anything of it. The noise was originally not happening, so I think it may have come off and I never even thought of it. This truck is my first project, AND my first exposure to mechanical knowledge.
I'll check for that hose at first light tomorrow!
Old 02-09-2019, 12:02 AM   #32
ga-stepside
It could be that the hose fitting was not tighten and vibrated out.
1967 C10 Step side
1970 AMX 390
Old 02-09-2019, 04:36 PM   #33
RhapidFyre
RhapidFyre's Avatar
The hose coming off the forward portion of the brake booster is going into a plug that's attached to the top of the intake, and the other side of the plug is going to a hardline towards the back. I'm assuming it's just bypassing the carb.
Old 02-09-2019, 05:38 PM   #34
ga-stepside
That should be fine, my AMX power booster come off the intake, its the same vacuum as the bottom of the carb. No clue what that hard line is for, possibly for the transmission.
1967 C10 Step side
1970 AMX 390
Old 02-09-2019, 05:47 PM   #35
Steeveedee
Who Changed This?
Steeveedee's Avatar
If I am not mistaken, that hole is threaded for 1/4" tapered pipe. A 5/16" fitting may still allow a small leak. Spritz the fitting with carb cleaner, and if the idle changes, get a 1/4" tapered pipe plug. It should seal with no thread treatments, BTW.
~Steven
Simi Valley, CA
Old 02-10-2019, 10:03 PM   #36
El Dorado Jim
yep, it should be a 1/4" tapered pipe plug that goes in there
El Dorado Jim is offline   Reply With Quote
