Rookie Quuestion - Wiring Related
Hi guys,
I am working on running the electrical for the rear lights, fuel pump and sender on my 65 GMC project. Where does the wiring go to? I assume it comes in the cab somewhere but I can't see the obvious. Of course the person that started this project may have covered it up, I'm starting with no knowledge as it was just a cab, front end and bed on a frame when I started. Thanks for the help! Joe |
![]() Join Date: Jan 2011
Re: Rookie Quuestion - Wiring Related
Well they did not have a fuel pump wire so just run it with the harness. That ran from the fire wall down to the frame on the drivers side to the back of the bed. There was a harness for the tail lights at the back. The fuel sending unit wire ran down the edge of the sil plate along with the wiring for the inside light and then along the top of the tank. I have a wiring harness out of a 65 GMC that is almost complete if you need one.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jan 2015
I ran all that wiring out of the fire wall and straight down to the frame rail. I ran it along the frame on the inside attaching it with rubber coated straps and tek screws when I rewired my truck.
Thanks for the replies.
I have the American Autowire kit so I'm making it from scratch nearly. When you say from the firewall do you mean in the engine compartment? If so what connector and any pics would be appreciated |
If you have the classic update harness for the truck just follow the instructions. The harness for the back plugs into the plug that is on the drivers side of the fire wall. The wiring for the sending unit in that kit has it running in the stock location. What I did was to bring it out the fire wall along with fuel pump power through the grommet for the oil pressure line. I then used the fuel pump wire to trigger a relay to power the fuel pump. The wiring ran across the fire wall and was added to the harness running to the back.
Jimmy
#6 | |
Thanks for the help. My harness is missing any instruction for the rear. It came with the project. I did complete the front harnesses and they both plug into the plug that comes through the firewall so there is no place for the rear to plug in. Joe |
#7 | |
Thanks for the help. My harness is missing any instruction for the rear. It came with the project. I looked on AAs website and they don't show a PDF of the rear harness for some reason. My kit is a 500560. I did complete the front harnesses and they both plug into the plug that comes through the firewall so there is no place for the rear to plug in. Here's a pic Joe Last edited by Pontitruck; 02-06-2019 at 08:14 PM. Reason: Adding pic and more info |
I have a kit at the house and I will pull the instructions out and see what it shows for the back. Been several years since I did the 65 so a memory jog will be good. I will post pics of the instructions if it looks like you have some missing.
Jimmy
meowMEOWmeowMEOW
When I was doing my LS swap, I got annoyed at the body side wiring harnesses, and decided to rip out all of the wiring from the firewall back to redo it.
I grabbed a wiring cart, and just decided to build my own wiring from the ground up. It was honestly easier than figuring out the 40+ years of solid core wiring splices and double-doubled butt connecters. IIRC it was less than 12 wires total .
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
![]() Join Date: Aug 2004
Mine runs from the plug on the firewall, angles (with a clip) down the cab to the drivers side frame rail, runs down it until the end of the plug. Your fuel sending wire used to be inside running in DS wiring run under the door sill, then back to the tank. I hope this helps. Good luck.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks guys, I wired the rear today and used a hole in the lower firewall the bring the wires out.
I looked at my 66 this morning and the wiring comes out through a hole over by the throttle linkage. Runs down to the frame and to the back.
Jimmy
