#25 |
Re: What master cylinder/proportioning valve to use?
If I were you, I would go route 2. Then after it works, and all good, ditch the hideous astro master and move to corvette master or what ever looks like it belongs in there. Lots of samples out there of setups that work. Just follow one, no need to reinvent the wheel. Capt fab even sells brackets, shows it's a common upgrade. Look at an implementation that works, follow it from the pedal to the lines, make your parts list then bust a move. You will be fine. It's an easy and fun upgrade.
![]() j
White K20 |
| Bookmarks |
