Old 04-05-2018, 12:59 AM   #1
RMBLFSH
Vent door seal
I need a new seal for the driver's side vent door that is located in the kick panel. The door works properly, but the seal is crumbling. I looked at Brother's, and found only the whole door. I could not find anything at LMC. Does anyone know of a source?
RMBLFSH is offline   Reply With Quote
Old 04-05-2018, 07:39 AM   #2
Jeff's72C10*
Active Member
Jeff's72C10*'s Avatar
Re: Vent door seal
Found this in the LMC catalog, item 3?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=78
Previous C10's
69 SB CST - sold
72 Cheyenne Super LB - sold
Jeff's72C10* is offline   Reply With Quote
Old 04-05-2018, 09:03 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Vent door seal
Board vendors Classic Heartbeat and GMC Paul carry these as well.
Old 04-05-2018, 09:08 AM   #4
RMBLFSH
Re: Vent door seal
Thank you!
Old 04-05-2018, 08:26 PM   #5
Daves70
Daves70's Avatar
Re: Vent door seal
I just cut my own out of an inner tube. Probably not "correct" but function is good and it's cheap.
Daves70 is offline   Reply With Quote
Old 04-06-2018, 08:51 AM   #6
indymachinist
Re: Vent door seal
At this point I'm going to give a BIG thumbs up to Classic Heartbeat.
I made an order thru them, and an order thru Brothers at about the same time. Classic Heartbeat is farther away from me than Brothers, but they got the order to me faster, and cheaper than Brothers did. The Classic Heartbeat box was probably 5x the size of the Brothers box yet shipping was significantly cheaper. Probably because Brothers pads their "cheap" prices with extra shipping and handling charges. ��
Also, the Brothers order came in wrong. Now over a month later the correct part they said they shipped has still not arrived. ��
Classic Heartbeat 1, Brothers 0
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 04-06-2018, 11:50 PM   #7
Ryan5O
Re: Vent door seal
I went through the trouble of replacing my vent window seal only to find out that the seal was too thick to close correctly. They dont cost much, but it was very time consuming and a waste. If I were you, I would only take a suggestion from someone who has actually done it; no offense to the vendors out there.
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 04-06-2018, 11:59 PM   #8
Ryan5O
Re: Vent door seal
... and if you find one that works, let me know.
Old 04-07-2018, 08:51 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Vent door seal
Mine were recently replaced for the blue blazer build - I haven't confirmed fitment yet but the seals didn't strike me as off much in terms of thickness.
Old 04-07-2018, 10:37 AM   #10
Ryan5O
Re: Vent door seal
Deadhead,
Since you already have them installed can you test it out and give us a report.
Old 04-07-2018, 11:13 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Vent door seal
Originally Posted by Ryan5O View Post
Deadhead,
Will do. These are at the resto shop w the blazer. I hope to get by next week. Pete
Old 04-07-2018, 03:01 PM   #12
67ChevroletDude
67ChevroletDude's Avatar
Re: Vent door seal
I located my vent seals at classicparts and mine were I think a little thicker, hard to tell when the originals were nonexistent, but they serve their purpose and I can close mine to where no air leaks through.
67ChevroletDude is offline   Reply With Quote
Old 04-10-2018, 10:09 PM   #13
Ryan5O
Re: Vent door seal
No one else wants to chime in on this one?
Old 04-11-2018, 11:09 AM   #14
HO455
HO455's Avatar
Re: Vent door seal
I did the one in my Burban with seals from Classic Parts. Small write up here post 232
http://67-72chevytrucks.com/vboard/s...698377&page=10
RIP Bob Parks.
Old 04-12-2018, 10:37 AM   #15
Ryan5O
Re: Vent door seal
That's a interesting discussion about the seals on page s 2 and 3. I had a similar problem and was too upset to contact the vendor to resolve the issue. Maybe its a character fault of mine, but sometimes I just want things to work/fit like they're suppose to. just thinking about it now gets me . At some point in the future I'll have to tackle it again...
Old 04-12-2018, 12:07 PM   #16
demian5
demian5's Avatar
Re: Vent door seal
Pow! That's how I did my 64 impala.
Great DIY
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-08-2019, 11:03 PM   #17
blackbart63mule
blackbart63mule's Avatar
Re: Vent door seal
Finally found the material for the in cab air vents. I did this because I could not find a “full” piece, the material is G. M. certified for gaskets, I WANT IT THE WAY THE FACTORY MADE IT, not with the middle cut out, the way all aftermarket are made! Bought enough to make lots of gaskets. In the next week or so will make one and fit it to see how it works.
blackbart63mule is offline   Reply With Quote
Old 02-09-2019, 06:20 AM   #18
OL SKOOL
OL SKOOL's Avatar
Re: Vent door seal
Just sandblasted mine. Let us know how you come out with your gaskets.
OL SKOOL is offline   Reply With Quote
Old 02-09-2019, 10:33 AM   #19
HO455
HO455's Avatar
Re: Vent door seal
Are the seals from Classic Industries coming with the center cut out now? The ones I got in May of 2017 were not.
RIP Bob Parks.
Old 02-09-2019, 10:41 AM   #20
HO455
HO455's Avatar
Re: Vent door seal
I haven't bought any new ones since I returned the ones I had but, I have heard they fixed the problem. You may still be able to return the ones that were mis-manufactured. Precision Rubber was doing what they could to make things right for me.
RIP Bob Parks.
Old 02-09-2019, 03:42 PM   #21
OL SKOOL
OL SKOOL's Avatar
Re: Vent door seal
Had to read your whole story awesome write up great detail. Hope you get the burb's body work done to your satisfaction.
Old 02-09-2019, 03:52 PM   #22
HO455
HO455's Avatar
Re: Vent door seal
Thank you. I'm in the que to get the damage fixed, however I may have a longer wait now that it has snowed here in raintown.
RIP Bob Parks.
Old 02-14-2019, 10:55 AM   #23
blackbart63mule
Re: Vent door seal
60-66 seals have the middle cut out, 67-72 seals are sold full piece it seems, and the material is just like a foam, not even rubber. I think I have a 67-72 vent door can use as a pattern, also, I need better weather so I can pull truck out to get to it.
Old 02-14-2019, 02:37 PM   #24
demian5
demian5's Avatar
Re: Vent door seal
innertube will last linger and probably seal just as well.
1986 C20 Scottsdale
Instagram: C10sofOC
