Old 01-06-2019, 08:39 PM   #426
Old57
Re: 57 GMC, frame swap, 4wd, 454 big block, 4 speed
And a pic of the transfer case shifter not going to work with the linkage due to the wrong location from the adapter kit bracket.
My 57 GMC build
Old57 is offline   Reply With Quote
Old 01-06-2019, 09:01 PM   #427
mongocanfly
mongocanfly's Avatar
wow....you aint wasting no time for that other gear!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-07-2019, 12:00 PM   #428
rgunlock
rgunlock's Avatar
Greg isn't kidding about you moving fast on this! I did brace up the shifter bracket, and that curvy piece of linkage didn't come close to working for me either. I attempted to fabricate my own. It fit and sort of worked, but it was real iffy whether both front and rear shift rods landed where they needed to when shifting. I ended up getting the twin shift sticks from ORD which took all the guesswork out. I hope your fabrication goes more successfully.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-07-2019, 10:54 PM   #429
Old57
I modified the transfer case linkage today and got it adjusted and shifting good. I used the stock NP205 linkage at the shifter, then TIG welded a cut off bolt to it and threaded into a custom pivot end that I had in the bolt bin, and attached to the 205 shift rail bracket. I took my drive shafts to Power Drive this morning, and they were done this afternoon. They got bought out by another company recently, and their somewhat high prices, but good work, turned into really high prices for good work! I'll keep that in mind for future drive shaft needs, and look at other options. Anyway, I installed the shafts and gave everything a final check, let it down off the lift, and took it for a test drive... holy moly, what a difference in shifting! I love it, and it's so smooth. I measured and marked out the new floor cover for my shifter holes, and I'll get that cut out tomorrow. I also need to modify the shifter to have a bend in it to move away from my leg, but that's no biggie either. I'll get those 2 things done, then get some more driving done.
My 57 GMC build
Old 01-07-2019, 10:57 PM   #430
OutlawDrifter
Right on, speedy work!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-07-2019, 11:10 PM   #431
6BT 56
6BT 56's Avatar
I'm ready to shed a tear of happiness for you . And ready to shed another tear cuz the updates will be slowing down a lot now that it's a driver . Lol.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 01-07-2019, 11:14 PM   #432
Old57
Thanks guys! I'll be sure to post updates and things with the truck as I get the "relationship" built up with it. Eventually, I want to get it painted too, so hopefully I can get that taken care of someday... I need to let the ol wallet recover for a while though
My 57 GMC build
Old 01-08-2019, 01:06 AM   #433
mongocanfly
nice..i cant wait to do some 5 gear shifting in mine
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-08-2019, 12:26 PM   #434
rgunlock
rgunlock's Avatar
Congratulations on the successful swap!
Rick
Old 01-08-2019, 11:26 PM   #435
G&R's57GMC
G&R's57GMC's Avatar
I just read through your whole build , Very nice , great job.
Here's my '57 GMC Napco for a color suggestion.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 01-09-2019, 10:10 PM   #436
Old57
Thanks guys! G&R, that is a great looking truck!
I got my shifter made how I wanted it, and it feels like the right location. I have the transmission cover marked out to cut for the shifter holes, and got the shifter boots today. Maybe tomorrow evening I can get that done and put in.
My 57 GMC build
Old 01-09-2019, 10:24 PM   #437
Black_Sheep
Black_Sheep's Avatar
Nice work Gabe!
Black_Sheep is offline   Reply With Quote
Old 02-15-2019, 12:30 AM   #438
Old57
It's been a bit since I had time to check out the forums. I haven't had the truck out as much as I'd like due to ice and with salt being put on the roads. Today it got up in the 60's, so I got it out a little bit. It was the first time that I got out on the highway with the NV4500 overdrive transmission. I'm turning about 2150 RPM at 70 MPH, which it great for the big block. I had a pretty hard drive line vibration at 60 to 70 MPH, so I rechecked the drive line angles when I got back. When modifying the transmission mount for the swap, and the shackle lift on the rear, I'm off 2 degrees. I ordered different shims this evening, so I'll get those changed when I get the new ones, and test it out again.
My 57 GMC build
Old 02-15-2019, 03:23 AM   #439
mongocanfly
vibrations suck.....hopefully thatll take care of it.....howd the nv do?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2019, 08:19 AM   #440
Old57
It did great, shifts good, etc. It's great having the overdrive!
My 57 GMC build
Old 02-15-2019, 09:37 AM   #441
Mains52
This build is awesome. It makes me really want to get my 52 done so I can start my Father inlaws 59. I may have to talk him into a frame swap. Great Work!!
Mains52 is offline   Reply With Quote
Old 02-15-2019, 11:26 AM   #442
Old57
Thanks! I'm happy with how everything turned out. I need to do some more driving to get the motor broke in and change the oil. Hopefully the new shims correct the driveline vibration. I might be taking it on a drive to Texas next month if everything works out good with it.
My 57 GMC build
Old 02-15-2019, 10:18 PM   #443
mongocanfly
The only gripe I have with the nv is I wish the reverse gear was a little lower...no fun with a loaded trailer...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2019, 10:22 PM   #444
Old57
Do you have the early or the late ratio?
My 57 GMC build
Old 02-15-2019, 10:55 PM   #445
mongocanfly
Both mine are 98s...5.64:1 instead of 6.31:1
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2019, 11:15 PM   #446
joedoh
joedoh's Avatar
yeah the weather has been nuts, up and down!
before you add shims make sure the leaf springs are "set", do a big smokey burnout!
Old 02-15-2019, 11:34 PM   #447
Old57
Ok, mine is the lower geared 93
My 57 GMC build
Old 02-15-2019, 11:36 PM   #448
Old57
Yes, it sure has. I'm ready for spring! The springs are definitely set, I've had a load of wood in the bed already
My 57 GMC build
Old 02-16-2019, 12:08 PM   #449
dieseldude4bt
Use low range in the t-case when backing the trailer.
I tell my wife all the time it's easier on the truck than slipping the clutch.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 02-16-2019, 12:13 PM   #450
mongocanfly
d-dude...I would but the c30 is 2wd
Mongo...aka Greg
RIP Dad
RIP Jesse
