05-30-2002, 07:37 PM | #1 |
seat/ sholder belts?
This 72 has belts I realy don't trust a whole lot. The 72's had a sholder belt option and I noticwe a small plug in the rear wall where one might install a belt ancor. Anyone out there ever put sholder belts in a 67-72? What's behind that plug?
Dave
72 C 20 350/4 sp, Ebay bargain! What's left is nice! |
05-30-2002, 08:30 PM | #2 |
Out of the carpool lane.
Behind the plastic plug you'll find a threaded hole. Don't worry about a nut falling out, it's welded on or something like that. Anyway, I've used S-10 shoulder belts and these work well. The only drawback is they aren't long enough for larger people. I'm trying to figure out a way to raise the base up to accomodate them. Some have tried Juliano's or Southernrods.com (probably the exact same belt), but I think they ran into the same problem.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
05-30-2002, 08:51 PM | #3 |
Here's a pic of the passenger side and what they look like:
05-30-2002, 09:02 PM | #4 |
Walking accident
Don't curse me out but I got mine at a junk yard out of a ford ranger (the old body style) and they fit perfect, even the middle belt.
Laurens, SC 69 C10 W/350 & 700R4 89 Mustang GT |
05-30-2002, 11:22 PM | #5 |
I paid too much for a set from Brothers.com. They are nice, though, and bolted right in.
05-31-2002, 01:24 AM | #6 |
Livin' it up.
I used a blazer as well. fit well but as brad said the female pieces are too short for bigger folks and not easy to use much either way. They work well but tough on the initial buckle for newbies.
Dont even try southernrods! i called them they said it'd work, then it got sent and too dang short to even fudge it. I sent em back and they docked me 25 bucks or something for a restocking fee plus i had to pay shipping back to them, GRRR. Brad if you figure out a setup for the female pieces let me know! My belts are outa a 85ish and have the bolt in the rear of the retractor on the floor. good luck
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
05-31-2002, 03:16 AM | #7 |
go bucks!
i used a flat piece of steel stock, about 2" wide x 5.5 long, drilled holes in either end for the bolts,and attached the female buckle end to the flat stock. it gave me plenty of room to insert in seat crease to attach male end as usual.the only drawback is that the pivot point at the shoulder pillar is down too low and it will seem like it binds you to your seat!very sturdy though w/ the added length supplied by the flat stock steel,it's as sturdy as the factory floor mounting position.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
05-31-2002, 03:57 AM | #8 |
Fords do suck but the ranger helped me out to
i got the weather striping out of one for free and it fir perfect i just had to cut it and the middle seat belt. but y the fck do u want a seat belt .
68 C10 lwb Blue 350ci 4:11 gears Mine 70 c10 lwb Green all oringinal execpt for the seats and steering wheel Dad's email=TriToRemember@yahoo.com Texan |
05-31-2002, 10:58 AM | #9 |
Walking accident
Just in case a cop pulls you over.
05-31-2002, 11:26 AM | #10 |
Buxman66, could you take a pic of what you're describing. I'm having trouble picturing a safe way to do this.
05-31-2002, 11:54 AM | #11 |
I bought mine at the LA Roadster show a couple of years ago from one of the vendors. They said would be no problem. However, when I installed them, they don't want to retract. I called them and they said "Oh, do you still have the gas tank in the cab? You'll have to remove it and then stand them straight up." Just another one of those don't fit situations!
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
06-01-2002, 02:07 AM | #12 |
go bucks!
down behind your seat are the seat belt holes(factory)w/a nut welded to the under side.take a flat piece of .125" thick plate steel, cut it down to roughly 2" wide x 5.5 or 6" long ,drill a 43/64" diam.hole for the bolts to go through,and place in your vice and bend the plate steel accordingly to lay flat against your floorpan,put a bend approx. 1"above the bolt hole to put the flat stock steel on a curve towards the back of your seat.the other end of the flat stock,mount your female end of your seatbelt to the flat steel, weasel the head of the female end in between the crack of the seat back and the seat bottom.all this does is doing is giving you extra length to move your seat forward and back and still have enough of the female end to buckle up to.use grade 8 bolts w/locking nuts and large washers.i used 5/8 bolts all around,and everything worked fine.sorry, no pic.though.
06-01-2002, 02:14 AM | #13 |
if anyones interested im going to have a pair of the gray retractable shoulder belts for sale very soon, they have the little earth/globe on the release button.
06-01-2002, 08:05 AM | #14 |
seat belts
You know, I have a friend who amongst other things, has driven stockers, draged mopars, wound out sports cars, and when he gets in my car, or truck now, he goes for the seat belts, no mater where we go. He had a baaad experience once, and was hit head on in a vw bug when he was 17. He was drunk, and he was going the wrong way on a one way road, but had the presence of mind to drop down and kiss the radio. Maybe saved his life, I don't know. If you never had an accident, you probably would never need them but this is not a perfect world.
Thanks for the help, have a great weekend everyone.
06-01-2002, 09:48 AM | #15 |
Don't forget the proper anchors
I bought some shoulder belts and a center belt, but I don't remeber who from. They were new and cost a bunch. They are worth it, seat belts are a hassle until you need them. A girl from work did a minor roll in her pickup, almost no body damage, and died from her body smashing about the cab. I always wear mine without appology.
Since you are doing this for safety purposes, never skimp. I bought some anchor plates from julianos to put under the floor pan. Your new retractors bolt to these (after drilling through the floor) and, when (not if) you get in a fender bender, the plate spreads the load and greatly reduces the chance of the belts completely pulling out of the metal. Julianos plates are designed with rolled edges, which again help spread the load without any sharp points, which will "tear" much quicker under a heavy load. DO IT RIGHT! or don't do it at all.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current) past rides were: '70 Chev 2wd farm truck '71 GMC 2wd 1/2T 402 nice! '72 Chev 2wd 1/2T 396 '72 GMC 3/4T 4x4 2500 Super Custom suburban. Bozeman, Montana |
06-01-2002, 11:39 AM | #16 |
Another option for seat belts is to do what I did. I bought a set of new take-out seats from a 2001 Silverado which has the seat belts in the seat. Killed two birds with one stone on that one. Got the shoulder belts and a much much better seat.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
06-02-2002, 09:47 PM | #17 | |
Seņor Member
Kenneth
