01-30-2019, 07:06 PM | #1 |
Frame cuts, 2wd 3/4 ton leaf spring, and dually 1 ton
$35-75 each plus shipping, price depends on how big you need. I have 2 rear frames. I also have a 68 1ton dually leaf spring frame.
01-31-2019, 12:53 PM | #2 |
Re: Frame cuts, 2wd 3/4 ton leaf spring, and dually 1 ton
I am looking for a pair of frame mounts for a 1/2 ton. These are the mounts that are riveted to frame that your leaf spring is mounted to my leaf is 2 1/4 wide is the 3/4 ton the same?
01-31-2019, 01:30 PM | #3 |
I will measure mine, I think the shape and mounting holes might be the same.
01-31-2019, 02:13 PM | #4 |
One of the First
Still looking for some rear shock upper mounts.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
01-31-2019, 03:02 PM | #5 |
01-31-2019, 03:05 PM | #6 |
One of the First
1970 / borrowed picture
01-31-2019, 07:18 PM | #7 |
My leaf springs are 2 1/4” wide the bushings are 2 5/8” wide so i believe mine are what you want. $85 shipped...it’s a lot of rivets to cut.
01-31-2019, 07:22 PM | #8 |
Picture of what I have, the frame is about 4.125” inside dimension where these mount.
01-31-2019, 07:26 PM | #9 |
I have multiple rear ends i could cut shock mounts from. These seeme to be the thickest ones.
01-31-2019, 07:44 PM | #10 |
These are lighter duty metal and much easier for me to get at
02-01-2019, 04:49 PM | #11 |
If it looks like this I’ll take them —- just want to make sure and when you give me the thumbs up I’ll shoot you funds with pay pal
02-01-2019, 05:27 PM | #12 |
I would say these are the same, rear mount
02-01-2019, 05:31 PM | #13 |
Front, it’s wider at the top than at the the bottom
Last edited by randy500; 02-01-2019 at 05:32 PM. Reason: Deleted pic orientatiom |
02-01-2019, 08:12 PM | #14 |
One of the First
Let me look around for the correct ones Randy. Thanks man!
02-01-2019, 08:20 PM | #15 |
02-17-2019, 06:09 AM | #16 |
So does this mean you still have these?
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-17-2019, 12:00 PM | #17 |
02-17-2019, 05:14 PM | #18 |
Well I seen the upper shock mounts for the rear while I was at work. But just measured my frame and I wasn’t thinking. This 157” chassis the rail is over 6” y’all back there. Maybe I could put a spacer in the lower side or do you have any upper shock mounts like the borrowed picture you posted?
02-17-2019, 05:30 PM | #19 | |
Did yours come with shock mounts? I have a 68 C30 frame here and it doesn't have any shock mounts. |
02-17-2019, 05:50 PM | #20 |
Mine did not. The ones you took the picture of with the triangular mounts. How much you want? I may could add another bracket and make them work, just a shock after all
02-17-2019, 05:53 PM | #21 | |
How about $45 shipped, cutting rivets sucks.... |
02-17-2019, 08:19 PM | #22 |
Payment sent
