![]() Join Date: Mar 2011
advice on manifold/carb combo SBC
I have a Plain Jane 350 out of a 70 burb stock motor no AC at the moment but I will later its got a 700r4 behind it not sure on the Stall... have recently changed my mind on EFI and have had good experience with Edlebrock on other builds open to suggestions and advice thanks in advance
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Re: advice on manifold/carb combo SBC
Edelbroke performer intake with 600 Holley.
Who Changed This?
![]() Join Date: Jan 2013
Build it bone stock. Millions of owners haven't been disappointed. I have a Q-Jet on my truck (factory carb, believe it or not!) and it works just fine. I've rebuilt it more than once, and it still works great. If you want to go to a dual-plane manifold, that wouldn't be a bad change.
Yup, like Steve said, the simpler you keep it, the fewer problems you’ll have.
The factory didn’t mass produce problems |
![]() Join Date: Mar 2003
Seeing all the Ls and diesel swaps here I thought I was going to be one of the few left that still had an actual period correct engine in my truck. Welcome
![]() Join Date: Dec 2006
What Steeveedee says. An old tired stock 350 won't gain much with a fancy intake and carb IMO. I put a kit in my Q-jet back in '97 or '98 and it's been flawless ever since, although I don't use a choke here, just the fast idle cam system.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Are you just gonna daily drive it? Since you're already familiar with using Edelbrock, I would go with the Edelbrock Performer EPS intake and a 1406 carb. Good combo on a stocker. Only issue is the accessories you have to buy for the carb. Great carb once setup well
72 C10 lwb fleetside -stock 350/350 combo |
Hey there I read your post when someone saved your ass as you nearly bought EFI and decided against it. Isn’t q jet meant to be best for gas mileage? But I think the edelbrock is similar design. If it’s gas mileage your concentrating on you could buy a wide band gauge and jet it for economy on the leaner side think that’s what I’m doing with mine when it hits the road this spring
Close to what other have mentioned. My $0.02 vote is for a 2701 Edelbrock Performer EPS intake and 1901 500 cfm electric choke.
