Old 02-18-2019, 03:45 PM   #1801
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Finished up the rough body work on the valvecovers, then laid a coat of self-etching primer. That will get a scuff, then filler primer, then some engine orange. I’m really liking the way these are turning out
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-18-2019, 04:47 PM   #1802
TA_C10
TA_C10's Avatar
Super clean, very nice.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-18-2019, 08:57 PM   #1803
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
Wow, everything that you've done recently looks great, Chris!
Love what you did with the valve covers and the firewall turned out super nice!
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 02-18-2019, 09:04 PM   #1804
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks a lot, guys! It was a bunch of work for something super subtle, but I am fully STOKED with how these are turning out:
First shot is post-sanded filler primer, prior to final prime, then sexy orange top coat
-Chris
Old 02-18-2019, 09:34 PM   #1805
Kronald_70GMC
Kronald_70GMC's Avatar
That is super cool!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 02-18-2019, 11:19 PM   #1806
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Kronald_70GMC View Post
That is super cool!
Thanks, bud. I’m liking them. I slapped them on the engine and I like ‘em even more:
-Chris
Old 02-19-2019, 02:50 AM   #1807
smbrouss70
smbrouss70's Avatar
I'm lovin' it! So what is going to grace the top of those valve covers? Script or CID decals?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-19-2019, 01:41 PM   #1808
gringoloco
A guy with a truck
gringoloco's Avatar
Keeping ‘em clean. I’ve even thought about painting the wilwood master cylinder cover to hide the logo...
-Chris
Old 02-19-2019, 01:43 PM   #1809
SCOTI
SCOTI's Avatar
I would be way ahead of you on that one. It would happen quickly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-22-2019, 09:52 AM   #1810
timmytimm3
Looking killer!
Have you seen the Vintage plug wires that Delmo sells?
https://www.delmospeed.com/product/vintage-plug-wires/
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-22-2019, 10:21 AM   #1811
SCOTI
SCOTI's Avatar
Originally Posted by timmytimm3 View Post
Looking killer!
I feel the 'vintage' appearance of those were used a little earlier than the 70's. A solid grey or black plug wire in 8mm or larger will look fine & get it done w/o the additional expense.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-22-2019, 11:04 AM   #1812
gringoloco
A guy with a truck
gringoloco's Avatar
Looking killer!
Thanks! I do like those, but also agree with Scoti. My plan is to hide them with coil packs at the rear of the engine and wires routed under the headers. It will be tight, but I’ll see if I can make it work
-Chris
Old 02-22-2019, 11:39 AM   #1813
jkeating1
jkeating1's Avatar
…..CID decals?
What are CID decals?
jkeating1 is offline   Reply With Quote
Old 02-22-2019, 12:13 PM   #1814
gringoloco
A guy with a truck
gringoloco's Avatar
Cubic Inch Displacement, this is what Steven did with his:
I like it, but I’m going for simple, smooth, and clean...
-Chris
Old 02-22-2019, 11:46 PM   #1815
gringoloco
A guy with a truck
gringoloco's Avatar
The Holley intake manifold is cast with only one vacuum port, which will be used for the brake booster. Given that, I was forced to drill and tap a few extra holes to accommodate the manifold absolute pressure (MAP) sensor, which will hide behind the throttle body, and the PCV valve, which just barely fits underneath the plenum floor. The PCV is a mid-60s GM V8 piece that uses 1/4” NPT on one end and a hose barb on the other. The plan is to plumb to the back of the valve covers for a completely hidden system.
I went ahead and mocked up the fuel rails, injectors, and fittings and am happy with the fit of everything. Time to get this thing in some color
-Chris
Old 02-23-2019, 01:21 PM   #1816
SCOTI
SCOTI's Avatar
Out of 'sight'. I dig it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-24-2019, 09:27 PM   #1817
gringoloco
A guy with a truck
gringoloco's Avatar
Dy-no-MITE! Sorry, couldn’t resist...
Apologies to everyone that wanted the intake to remain raw. Water pump is next, then accessories.
-Chris
Old 02-25-2019, 01:56 AM   #1818
cornerstone
cornerstone's Avatar
YES! YESS!! YESSS!!! This was the absolute right way to go with your truck...I would say the overall design is "understated perfection", like when the most beautiful lady in a modest dress enters the room and all the other wanna be's with goo-gobs of make-up and mini-skirts get mad. I will probably dream about how good it will look with a black air cleaner tonight.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-25-2019, 02:14 AM   #1819
3757chevy
3757chevy's Avatar
That's Truck Porn right there.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-25-2019, 09:51 AM   #1820
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like the engine is coming together
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-25-2019, 11:28 AM   #1821
gringoloco
A guy with a truck
gringoloco's Avatar
This is how I feel, too. The chrome and raw looked good, but the orange and black gets my motor runnin’.
What if I told you I was thinking of doing an air cleaner like this, too much?
-Chris
Old 02-25-2019, 11:29 AM   #1822
gringoloco
A guy with a truck
gringoloco's Avatar
Haha, I’m a little hot-and-bothered over here myself
Slow and steady wins the race
-Chris
Old 02-25-2019, 12:24 PM   #1823
cornerstone
If it turned out you needed a dual snorkel for lack of air, so be it. I have seen others do a similar setup (MetalDoc) and I’m pretty sure it reduced the sound of the rushing air when at WOT. My thought would be to stay on the simple side if you can get away with it. Either way it’ll be great.
Brian
Old 02-25-2019, 12:36 PM   #1824
SCOTI
SCOTI's Avatar
No.... It's not two much
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2019, 06:09 PM   #1825
gringoloco
A guy with a truck
gringoloco's Avatar
Im leaning towards stock appearance, but not. This fits right in. We’ll see how I feel about it when the time avails itself. Right now, there are about a million other things ahead of it on the list...
Yeah, 3 would just be weird, except for that one time in Total Recall...
-Chris
