72 Cheyenne
fuel gauge question
my gauge stopped working so I checked the sending unit (it's good) swapped the gauge with a working one but it still won't work, we tested everything we could think of. Any ideas? I'm thinking maybe the circut board is bad?
Location: biwabik, minnesota, what is this white stuff out here
have u checked the wire going from the tank to the fuse block?
72 Cheyenne
yup, still nada
![]() Join Date: May 2002
Try a new temporary ground at the tank itself--if that works you can then replace with a permanent one.
Stepsides look like real trucks! Smitty ![]() |
I had the same problem once. I drove me nuts until i found a layer of corrosion on the mating surface of one of the nuts that connect the post to the circuit board. Scraped it off and everything is happy.
1967 Chevy LWB Fleetside 350/400 (Worn Smooth Out) Resto in progress It may be ugly but at least it's slow!! |
