02-21-2019, 04:43 PM | #1 |
Need help with bolt size
I am finally installing my steering column and I don't have all of the bolts. I have the brackets, but not the bolts. I am trying to figure out what size the bolts are that hold the bracket that the lower part of the steering column straps to just outside of the passenger compartment, below the master cylinder. I have circled the holes in blue ink on some pictures I had. Can anyone help me here?
Thank you in advance.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
02-21-2019, 04:55 PM | #2 |
Carpe manana
Re: Need help with bolt size
This might help: http://67-72chevytrucks.com/vboard/s...&postcount=173
02-21-2019, 04:56 PM | #3 |
Carpe manana
02-21-2019, 10:56 PM | #4 |
Column cover (engine side): The column cover mounts over a portion of the toe pan seal. The cover mounts to the firewall using:
• One (GR 5) 1/2" hex bolt and lock washer. The bolt thread is 5/16-18 x 1.1/2, of which 1/2" is shaft. This bolt also secures the brake booster bracket. The column cover slides underneath the booster bracket. NOTE: The bolt head is stamped "ROCKFORD". • One (GR 5) 1/2" recessed hex tapered bolt with a 1" OD integrated washer. The bolt thread is 5/16-18 x 7/8. NOTE: The bolt head is stamped with an anchor. Very cool bolt BTW, it's not a flange head like most recessed bolts
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-22-2019, 10:33 PM | #5 |
Im going out to see if my bolt heads have all those markings
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-23-2019, 12:13 AM | #6 |
Ha ha......Be interesting. "Rockford" kind of threw me off, doesn't seem original, but my guess it is. Pulled two other Rockfords off my truck, same bolt only 1/4" longer. They mount the combination valve.
02-23-2019, 10:25 AM | #7 |
Thanks DeadheadNM and 71CHEVYSHORTBED402. That definitely helps!
