Old 02-22-2019, 04:45 PM   #1
cornerstone
cornerstone's Avatar
Smoothing Firewall
Hey guys... I've done enough searching today so that I'm running out of time to actually get some work done on this truck. You know how it is, "I'll just take a quick peek at the forum....". So I'll just ask the question, when smoothing the firewall and using the Vintage Air kit, should I remove the section of the factory firewall that the V/A panel will cover, or just leave it and cover up the old firewall?
Brian
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-22-2019, 04:50 PM   #2
OARNGESI
OARNGESI's Avatar
Re: Smoothing Firewall
Most smooth it and not use the panel
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-22-2019, 05:02 PM   #3
Getter-Done
Getter-Done's Avatar
Last year I went to the Rod run in Pigeon Forge.
The trucks parked on the strip with the smooth firewalls
looked so much better.
I will put an Old air system in mine.
Before seeing the difference in person (and not just pictures)
I would not have distorted my new toe panel.
Now I will make it smooth. Just my 2 cents.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 02-22-2019, 05:10 PM   #4
lks dcvn
lks dcvn's Avatar
smooth it!
lks dcvn is offline   Reply With Quote
Old 02-22-2019, 05:29 PM   #5
cornerstone
Thanks ORANGESI...
How about you Getter-Done, would you leave the original or cut out or cover original?
And how about you, lks dcvn? did you cut out, or just cover the original?
Brian
Brian
Old 02-22-2019, 05:32 PM   #6
lks dcvn
lks dcvn's Avatar
the old firewall holes were filled with new metal.
Old 02-22-2019, 05:39 PM   #7
cornerstone
Thanks. That makes 2 consistent answers....
Brian
Old 02-22-2019, 06:01 PM   #8
Getter-Done
As of right now I plan to cut it out and fill with new metal also.
Here is my new toe panel.
Here is a picture from a member (Rod Run)
This is what I want it to look like.
The main truck that changed my mind was
meeting Member jhrusk and seeing his truck
in person changed my mind.
Here's a pic of his firewall.
Hope they don't mind me
copying there pics.
84 Chevy K-20
Old 02-22-2019, 06:32 PM   #9
cornerstone
Oooo I can see why! Both of those are niiiiice.......I've spent some more time looking around and have seen them done both ways, on very nice builds. It seems easier to me to just cover up the stock wall with the supplied V/A plate, but I was concerned with the firewall being to thick and causing AC install problems. Plus, usually the easier path is not the best path from what I've learned.
Brian
Old 02-22-2019, 07:49 PM   #10
Grumpy old man
Grumpy old man's Avatar
I'm finishing mine this weekend , I smoothed and shaved the complete gutter rail off also removed the hump on the pass side .
Old 02-22-2019, 08:21 PM   #11
cornerstone
Hey Grumpy.... what you mentioned (completely shave the gutter rail off) actually seems like a faster way than adding a strip of metal to close in the gutter channel. They both look clean to me so I may do that.
Also, was the hump that you removed where the black circle is on the picture?
Finally, The red circle seems to be where you have the holes for the AC lines, which would give an even cleaner look. 😋
Brian
Old 02-22-2019, 08:48 PM   #12
Grumpy old man
Yes , Remove the hump in the black circle it serves no purpose and you get a cleaner line to match the drivers side . I cut the complete gutter rail off using a cut off wheel taking 3" sections and welding the panels back together as I went across and added a heavy bead of panel adhesive inside the cab at the joint just because , made a template of the rounded section on the drivers side and fabed a new panel to weld in on the pass side to match . the windshield washer hoses will run from inside the cab into the cowl so they still work but won't be seen , dist and starter wires will run down from fuse block and across toe panel seam . I'll post a couple more pics in a few minutes .
Old 02-23-2019, 09:55 PM   #13
gphillips72wagon
Please post pics after removal of the windshield/door rain gutters!
gphillips72wagon is offline   Reply With Quote
Old 02-23-2019, 09:59 PM   #14
Andyking1203
I completely smoothed mine, using metal. It's not close to being done yet.. I also got rid of the wireing gutter
Andyking1203 is offline   Reply With Quote
Old 02-23-2019, 10:04 PM   #15
Grumpy old man
I removed the gutter under the hood used to run wires look at the pictures there is a big difference between smoothing (Filling holes ) and shaving (removing metal off) .. I'm not removing the roof line gutter. I'm considering installing a vinyl top on this truck using the stainless roof line trim .
Old 02-23-2019, 10:47 PM   #16
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Smooth it out. Still planning to install VAir.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-24-2019, 01:57 AM   #17
cornerstone
Looks like you guys have been busy! I decided to use the Grumpy method for the channel. First section I cut was about 4 inches and I removed pretty much the whole “lip” of the outer channel. I took too much metal off which made welding a real pain. I kept blowing out holes. I had to put a welding rod on the upper inside of the firewall in the cab in order have enough metal for me to tie it back together to get out of that dilemma. Not wanting to go through that again, I then I sliced the top 3/16 off of the “lip” and tipped it over, laying it down to match the profile. That went well and gave it more strength, since it would now be a few layers of metal. After tacking about 250 small spots it was all together, so then it was time to grind it down smooth and get the first layer of duraglass on. Anyways, here’s how it went....
Thank y’all for the input!!
Brian
Old 02-24-2019, 09:09 AM   #18
derotoreut
derotoreut's Avatar
I didn't cut the lip of the gutter off. Instead I formed metal and closed it in. Made a thicker piece at the center hump, which personally I liked better.
~ Dan
Old 02-25-2019, 05:36 AM   #19
Grumpy old man
Well ...This is what I ended up with this weekend , A few more hours of finish work and I'll call this piece of the elephant done .
Old 02-25-2019, 11:32 AM   #20
cornerstone
Looks great Grumpy. Please post more pics when you get this thing completed or maybe a build thread? By looking at your parts list I’ll bet it will be one tough truck.
Brian
Old 02-25-2019, 02:21 PM   #21
cornerstone
This is as far as I was able to get til now.
Brian
Old 03-18-2019, 07:10 PM   #22
62bagger
62bagger's Avatar
Really nice work. the firewalls look like what I hope to end up with. I have a couple of questions. I have 2 access panels on my 62 and none of the trucks in this thread have them. Did you remove them or is it just the 62 that has them.
I also noticed that almost all the holes were filled. how will you run your wires? Do you plan to drill new holes as needed?
62bagger is offline   Reply With Quote
Old 03-18-2019, 10:09 PM   #23
derotoreut
derotoreut's Avatar
May want to search the 60-66 section instead of the 67-72 section for similar firewalls and answers to your questions. Yes all my holes were filled, so I will have to come up with some wiring access. I plan to use the fresh air vent areas for AC on passenger side and wiring on driver side.
~ Dan
Old 03-19-2019, 09:40 PM   #24
cornerstone
Sheesh. That was probably 12-15 different layers of filler. I was afraid of laying in on to thick so I crept up to level with many thin skim coats. It’s still not perfect but what is....
Brian
Old 03-19-2019, 10:35 PM   #25
Grumpy old man
Looks familiar , They look better without the hump on the pass side
