extra parts
looking to pass on a few more extra parts
ash tray $100 shipped SOLD!!! 4speed reverse setup with nos switch $100 shipped SOLD!!! Last edited by pimpston65; 02-23-2019 at 03:45 PM. |
Re: extra parts
![]() Join Date: Jul 2016
Re: extra parts
I will take the 4 speed reverse set-up stuff.
please pm your preferred method of payment. thanks.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
Re: extra parts
Re: extra parts
paypal sent.
no i dont have the wiring.
Re: extra parts
Re: extra parts
here's the wiring setup. i can make up the part that connects to the switch with bullet looking crimped ends, one light green the other dark green. the dark green will go to the panel on an extra side blade while the light green wire will go to the outside connect to the back.
Re: extra parts
i will need to repurpose a set of rear lights for the bullet looking crimped end that goes to the switch
Re: extra parts
that would be helpful. do you want some more $?
Re: extra parts
Re: extra parts
ok here's the harness for the switch, i'll measure again for final length, solder the breaks then retape the part that goes under the mat with black tape. should be done thursday. oh and i'll cleanup the mounting ring and such...
Re: extra parts
looking good,thanks for the extra parts and effort.
i like when the "bits and pieces" can be used.
Re: extra parts
Harness done. I got these items to repair the set screw, I can fix it or send you the “rebuild kit” I made up. Just let me know. I will also try to back out the original set screw first.
Re: extra parts
if you are having fun go ahead and try to fix it , then you can keep your tap and drill bit.
#15 |
Re: extra parts
#16 |
Re: extra parts
pm sent if you have a chance can you post a picture of the items.
#17 |
Re: extra parts
here's how i did the spliced sections
#18 | |
Re: extra parts
will post pic then. thanks for the extra parts and work.
#19 |
Re: extra parts
now i just need to get on my engine rebuild so i will have a use for back up lights.
#20 | |
Re: extra parts
| Bookmarks |
