02-20-2019, 11:36 AM | #1 |
S10 conversion header question
Believe me, I think Iv'e read every post from every forum and hadn't found an answer. Will the S10 small block conversion headers work with a block that has ANGLED Plugs?
02-20-2019, 02:40 PM | #4 |
Re: S10 conversion header question
Hedman
253.95 1982-2000 S10 with Small Block Chevy 1-1/2" Tube Diameter 2.5" Collector Diameter Shorty Design For Automatic Transmissions Only GM Style Angle Plugheads Uncoated S10 Engine Swap Street Headers Will Not Work with aftermarket cylinder heads including: Brodix, AFR, Edelbrock, Dart Jegs, Holley, World Products ADD TO CART
Jan's 53 |
02-20-2019, 03:19 PM | #5 |
Thanks so much! I’m gonna check em out right now. Anyone know of a manifold that will work?
02-20-2019, 03:35 PM | #6 |
I think you need to be clearer about what you’re asking. I’m assuming you’re talking about a sbc swap. So more info will help us steer you in the right direction.
What year of truck you have, motor and trans you’re planning on using etc,etc......
Jan's 53 |
02-20-2019, 09:00 PM | #7 |
Ha
That would probably help. 350 sbc with turbo 350 in a 1950 on a 85 s15 frame. The engine and tranny are tacked in and you can see the exhaust manifold may or may not work on the drivers side. |
02-20-2019, 10:28 PM | #8 |
Ok, so you and I are running same frame, motor and tranny. So by manifold are you talking about intake or exhaust?
I moved the motor to the passengers side about 3/4 of an inch to help clearance the steering.
Jan's 53 |
02-20-2019, 10:45 PM | #9 |
I was talking exhaust manifold. If I move the motor over, does that cause alignment problems with the tranny not being exactly centered in the frame?
02-21-2019, 10:27 AM | #11 |
Are you using those headers you posted? If so, is your steering shaft passing through the header like they do on the Patriots?
02-22-2019, 04:05 PM | #12 |
You may want to look at my build thread. I have an SBC 350 swap on an S10 Frame. I used the Hedman headers and I believe the first page of the build thread has the details.
Here is the driver's side with steering.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
02-24-2019, 09:47 AM | #13 |
Thank so for the great pic. However, I need to know if the steering column passes through the other headers. The ones linked above for angled spark plugs.
02-24-2019, 08:50 PM | #15 |
Thanks so much!
