Old 02-27-2019, 04:07 AM   #1
toolboxchev
Re: Starter gear
Flex plate bolt not tightened enough or has a washer under it.
toolboxchev is offline   Reply With Quote
Old 02-27-2019, 10:42 AM   #2
rcazwillis
Re: Starter gear
No washers. Possible one is loose.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-27-2019, 01:54 PM   #3
toolboxchev
Re: Starter gear
The stock ones have somewhat of a small or shallow/short profile. I believe they are a grade 8 with a fine thread. If they stick out too much they will tick or knock against other equipment like the starter and such.
I have seen it before, not tightened enough, or loosened up ticking on the starter.
Hope this helps! Flex Plate to Torque Converter Bolt to be specific.
Old 02-27-2019, 10:19 PM   #4
Mike C
Mike C's Avatar
Re: Starter gear
The unsupported nose Hitachi style starters come with a spacer ring that moves the drive gear further away from the flexplate.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
