![]() Join Date: Jan 2016
Front lowering spring option
I added some 1” lowering blocks to the rear trying to get the stance better and more level. I like the way the rear looks but now I think the front is a little too high. I have 2.5” drop spindles on the front and what I assume are stock springs and shocks. It is hard to tell from this picture but I think if I add 1 inch lowering front springs I will be where I want to be. The other option is cutting the springs. I have never cut a spring so I have no clue how much to cut off to achieve a 1 inch drop. Any help would be appreciated.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
laying low
![]() Join Date: Mar 2001
Re: Front lowering spring option
Cutting 1 full round off the bottom of the spring generally nets you a 2" drop. So cutting 1/2 round should net you approximately 1" drop. I used a 4 1/2" grinder to cut mine.
![]() Join Date: Nov 2018
Your '67 has leaf springs? Or am I mistaken in that you can't use lowering blocks with coil springs?
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
#4 | |
If the springs are original they may be sagging down an inch already. That's the not so fun part of figuring it out. So one inch lower springs may not change anything... But how do know.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
Yeah I know that is a concern. But this truck was "refurbed" only a few years ago so I'm hoping that won't be an issue.
If I only cut off a 1/2 round will that mess up how the springs sit on that control arms? New territory for me.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 03-03-2019 at 10:22 PM. |
laying low
No. The spring will still index the lower control arm in the same spot. Nothing to it.
Thanks. I had read about the spring sitting with the nub in a certain position. Just watched a video and they explained that it sits on the lower control arm and the top of the spring just sits in a cup. So I assume you make the cut on the top of the spring. Shoot, maybe I'll give this a shot, the stock spring will probably end up a throw away anyway, nothing to lose but time.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 03-07-2019 at 07:24 PM. |
Yeah you are mistaken, LOL. I have coils.
If you will look on YouTube you will find some videos that show how to use a tape measure to more accurate cut the coil spring. It depends on how the end wrap is done on the spring to how much the first half coil lowers the vehicle versus the second.
Just start small...
#12 | |
You don't need to bend the spring on a Chevy truck, one end is flattened that goes up, and the end that goes into the A-arm you can just cut to desired length.
Okay! I was thinking you cut the top. Thanks for that infomation
#15 |
Well I chickened out on cutting the springs. But it looks like I will be doing it anyway. Turns out I got caught in the sagging spring thing. As stated before a 1" lowering spring may actually raise the truck, that happen to me, raised it 3/4". So I am going to cut the old springs and see what happens. BTW swapping the springs was a totally uneventful project. I bought one of these from Harbor freight for the tie rod and upper ball joint removal, awesome tool.https://www.harborfreight.com/3-4-qu...tor-99849.html
#16 | |
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#17 | |
#18 |
Well I am declaring victory. I should have listened to y'all about cutting the stock springs. I measured for a 1" cut and did the cutting with my 4 1/2 cut-off. The result was exactly what I was hoping for. Live and learn, anybody want a set of brand new Belltech 1" front lowering springs?
#19 |
laying low
Looks good too.
#20 |
Thanks.
BTW you might try some shock designed for lowered suspension to help that bouncy/choppy feel. I used Belltech Street Performance S2208 on the rear and 2103HA on the front. Expensive but really awesome shocks.
