03-03-2019, 01:33 PM | #1 |
1972 GMC 3500 Rear Wire Harness
Howdy - Looking at the attached photos there is a 4 wire connector and a gold anodized cylinder with a red wire hanging from it that I am not sure what these are for. Both are at the rear bumper. Any help appreciated. Thanks!
03-03-2019, 02:15 PM | #2 |
The Older Generation
Re: 1972 GMC 3500 Rear Wire Harness
Your rear light harness plugs into the 4 wire connector. You should have a short harness that will plug into it that goes to the tail lights, reverse lights & license plate light. Don't know what the cylinder is. What is on the other end of it? LockDoc
03-03-2019, 03:23 PM | #3 |
Did this truck ever have a slide in camper in it.?
03-03-2019, 04:09 PM | #4 |
Yes it did.
03-03-2019, 04:56 PM | #5 |
Looking at that connector again that is the end that is connected to the rear lights. The other half should be stuck in a hole in the rear cross member. Be sure and clean the terminals up before connecting it together..... LockDoc
03-03-2019, 05:05 PM | #6 |
The extra plug will be for the lights for the camper.
03-03-2019, 05:48 PM | #7 |
OK, For the camper tail, license plate & reverse lights. That makes sense. Thanks. LockDoc
03-03-2019, 07:53 PM | #8 |
All - thanks for your input - once I looked around underneath I was able to find the mating connector for the rear lights on the cross member drivers side. I also noticed a similar connector at the firewall by the distributor that was not plugged in for some reason. All good now!
03-03-2019, 10:42 PM | #9 | |
Good deal! Glad you have it working. LockDoc
