Did someone say MUD?
gas tank R & I question?
how hard is it to change the tank on a 78 3/4 4X4 longbed it has dual tanks also any help would be greatly apprecited Thanks in advance Michael
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
![]() Join Date: Dec 2003
Granted, all this info is coming from a 76 1/2 ton. But I don't remember any differences on any 3/4 ton's I've seen.
Its easy. Go under the truck, support both ends of the gas tank (i used jacks with wood blocks and made sure the tanks were as empty as I could get them by driving it around) then unbolt the filler necks from the body and slide them down. Remove the 8 9/16" bolts that pass through the frame rail into the mounting brackets for the gas tanks (4 bolts at either end). Unbolt the 1/2" ground cable bolt that passes through a hole nearby in the frame. Slowly lower the jacks down until you can reach up and disconnect the gas lines and sending unit power feed. Lower the tank all the way. Installation is the reverse. |
Hey thanks man that helps me understand it a bit preciate it
