03-04-2019, 09:02 PM | #1 |
What's the deal with Delco Spark Plugs?
71 C-10 402
Getting around to replacing the spark plugs on the project, and have to ask, how can spark plugs be difficult?...............EDIT, Because, I forgot my heads are off a late 60s HP 396The rest is nonsense....... I picked up Delco R44T from Napa, and checked out the part number, but I can't start the threads. The old plugs (Autolite) and the Delco are a 9/16" fine thread 18, but if anything the old threads are cleaner. They install with ease, and no issues since originally installed, 15-20 years ago. Delco is a shorter thread and doesn't take a lock washer I guess. I don't recall seeing them without one, but I suppose they work - assuming you can install them to begin with So what the heck? Possible the Autolite compromised the threads in the heads somehow? I've installed 3-4 sets of new plugs since I've owned her, never a problem. Edit: Interesting. AP 404 Autolite doesn't cross reference to R44T, same vise versa. Something is peculiar. Ah SNAP!, I just remembered my heads are HP off a late 60's Corvette or Camaro. I wouldn't expect so, but that's got to be it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-05-2019 at 01:36 AM. Reason: Oooooooooops. Left for entertainment "value". |
03-04-2019, 09:35 PM | #2 |
Re: What's the deal with Delco Spark Plugs?
The difference is the date of manufacture of the head. Earlier heads, prior to 70 I believe, have the straight threads with the washer. Later heads have the newer style threads which do the sealing themselves. If you select plugs for a 68 Chevrolet Camaro SS w/396, you'll get the right ones! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-04-2019, 09:40 PM | #3 |
Two different spark plugs for two different style heads .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-04-2019, 09:43 PM | #4 |
Who Changed This?
I deleted my previous post after looking at you old plugs again. You did not get the correct plugs from the parts store. Those are for a SBC, which I believe did have tapered seat plugs in 1970. You need plugs with the 3/4" "N" designation reach, and not tapered seats, but the compressible washer like on the old plugs.
03-04-2019, 09:44 PM | #5 |
BINGO!..................Ha, I used to know that...Been so long since I replaced the spark plugs. And I'm getting old
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-05-2019, 05:56 PM | #6 |
Earlier heads used a flat surface with a washer on the plug. AC plugs are numbered such example R44T is resister plug 44 heat range T designates flat sealing surface with washer
R44ts as used in later heads R is resister 44 is heat range and the ts is taped seat Correct me if I'm wrong.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
03-05-2019, 10:10 PM | #7 |
oy vey !
'67 GMC 2500, 292, 4spd, AC |
03-05-2019, 11:58 PM | #8 |
So much for the idea they're 9/16"-18 threads. Pretty close I guess
03-06-2019, 01:15 AM | #9 |
03-07-2019, 02:22 AM | #10 |
Now have fun and go to Autolites web page and try and figure out their nightmare. Especially when it comes to crossing regular plugs with the race applications.
03-07-2019, 09:38 PM | #11 |
A cross thread provides the best seal possible I'd keep trying with the wrong plugs until they catch. Then crank 'em in with a cheater bar!
03-07-2019, 10:07 PM | #12 |
ruff crowd
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-08-2019, 01:12 PM | #13 |
Couldn't get em to start, even after taking a sledge hammer to them. Thought I had em, but the plugs just break in half. I may try some epoxy
03-08-2019, 10:09 PM | #14 |
Carpe manana
Now that’s solved what’s the deal with AC Delco making plugs in China
03-08-2019, 11:54 PM | #15 |
Drill out the holes, shove the plugs in, and weld those puppies in place!
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
03-09-2019, 12:18 AM | #16 |
Was thinking that - right after I mentioned epoxy, ha ha, imagine if you didn't do it right A weld is permanent
