Old 03-09-2019, 11:14 AM   #1
dbm52
Re: Disc brake conversion
Might as well get the rear axles while your at it. You'll have 5 lug in front 6 in back if you don't.
dbm52 is offline   Reply With Quote
Old 03-10-2019, 12:20 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Can't use the 5 lug 71-72 axles in the 1970 and ealier housings. The axles are too long.
Moser makes a 5 lug conversion axle that is the correct length for 1970 and earlier housings. I used a set on my 1969 C10 12-bolt, and I also have 1972 GMC C15 5 lug disc brake stuff up front.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
